License levels
There are 5 license levels for BricsCAD:
  • BricsCAD Lite
  • BricsCAD Pro
  • BricsCAD BIM
  • BricsCAD Mechanical
  • BricsCAD Ultimate
BricsCAD Lite
If you only create general 2D designs, BricsCAD Lite may be the right choice for you. Compared to AutoCAD LT®, it also allows to view, move, copy, or mirror 3D models. However, it is not possible to edit the model or create new 3D entities. BricsCAD Lite also runs Lisp routines. Lisp allows BricsCAD users to load customized routines or small applications that will run in BricsCAD.
BricsCAD Pro
BricsCAD Pro includes direct 3D modeling with a full 3D constraint system, rendering with materials and lighting and access to third party applications.
BricsCAD BIM
BricsCAD BIM includes all BricsCAD Pro features. You can use your current CAD skills to smoothly move to creating real Building Information Models in record time. One product, one workflow, all in industry-standard DWG.
BricsCAD Mechanical
On top of all BricsCAD Pro features, BricsCAD Mechanical includes a complete mechanical design toolkit, all in industry-standard DWG, including sheet metal functionality.
BricsCAD Ultimate
BricsCAD Ultimate combines the BricsCAD BIM and BricsCAD Mechanical features.
