Network license server
To make a network license available in BricsCAD® on a client computer, the network administrator needs to install a network license server from Reprise Software first.
Bricsys Network License Manager is a separate program which installs the server. After starting the network license server, you can configure it through a web interface.
Just like BricsCAD® needs a license file to run, the network license server needs a network license file that you can activate online or manually.
You can activate a network license only once and it is locked to the server.
Once the network license is activated and the server is started, you can use the network license in BricsCAD® on a client computer.
Note: Reprise Software does not offer a network license server for Mac computers. However, you can install a Windows or Linux network license server to serve licenses on Mac client computers.
