Network license server
To make a network license available in BricsCAD on a client computer, the network administrator needs to install a network license server from Reprise Software first.
Bricsys Network License Manager is a separate program which installs the server. After starting the network license server, you can configure it through a web interface.
Just like BricsCAD needs a license file to run, the network license server needs a network license file that you can activate online or manually.
You can activate a network license only once and it is locked to the server.
Once the network license is activated and the server is started, you can use the network license in BricsCAD on a client computer.
Note: The Network License Manager is not available for macOS. However, you can install a Windows or Linux network license server to serve licenses on Mac client computers.
