When the Network license server (also named RLM License server) is running, you can configure it in the Reprise License Server Administration web interface.
Opening the web interface
If the network license server is not running, click the License Server shortcut in the Start menu (on Windows 8.1 or higher: right-click > Run as administrator).
A console window opens.
Browse to http://localhost:5054.
The Reprise License Server Administration web interface opens.
