Overview of install options
  • BricsCAD comes as a single download file for all license levels, including BricsCAD Shape.
  • When you install a new BricsCAD version for the first time, you can run a 30-day trial mode.
  • You can install each new major version next to a previous major version.
Interactive installation
In case of a normal (non-silent) installation, the user provides the necessary installation input via dialog boxes.
The user interface of Windows Installer queries the target system and displays Setup Wizard. Setup Wizard enables the user to change various options that affect the installation.
Silent installation
In case of a silent or quiet installation, the Setup Wizard user interface is disabled and the actions during the user interface sequence are not performed.
