Creating a drawing
A new drawing is always created as a copy of a template drawing. The default template is saved through the BASEFILE system variable.
In BricsCAD you can create new drawings:
- In the Start tab.
- Using the QNEW command.
- Using the NEW command.
- Using the NEWWIZ command.
- Double-clicking a *.dwt file in a Windows Explorer window.
Specifying the template folder
- Open the Settings dialog box.
- Under Template Path (TEMPLATEPATH system variable). , select
- Click the Browse button.
- On the Browse for folder dialog box, select a folder, then click the OK button.
Setting the default template drawing
- Under , select the BASEFILE system variable.
- On the Choose a File dialog box, select a drawing file (*.dwg) or drawing template (*.dwt), then click the Open button.
Using the Start tab
- Click the Start tab.
Launch the GOTOSTART command to open the Start tab if necessary.
The name of the current drawing template is displayed beneath the New Drawing button.
- Do the following:
- (option) Click the template list* button, to choose a different template drawing.
- Click the New Drawing button.
* All template drawings in the Template folder matching the current workspace (Drafting, Modeling, Mechanical or BIM), are listed here. Choose Moreā¦ to see the full content of the Template folder.
Creating a drawing using the default template drawing
First method:
Click the + button at the right hand side of the document tabs.
Second method:
Launch the QNEW command.
Third method:
- Launch the NEWWIZ command.
- On the Create New Drawing dialog, choose Start from Default template, then click the Next button.
Creating a drawing using the New command
Launch the NEW command.
On the Create New Drawing dialog box, choose Start from Scratch, then click the Next button.
- Choose between either Imperial or
Metric default settings.
Click the Finish button to create the drawing.
BASEFILE | PSTYLEPOLICY | CTB or STB? |
not specified | OFF | STB |
not specified | ON | CTB |
specified | ON or OFF | as defined in the template drawing |
Setting the Plot style policy
- Under Plot style policy (PSTYLEPOLICY system variable). , select
- Do one of the following:
- Choose Associate an entity's plot style with its color for Color dependent (CTB) plot styles.
- Choose No association between color and plot style for Named (STB) plot styles.
Creating a drawing using a template drawing
On the Create New Drawing dialog box choose Start from template, then click the Next button.
- Choose a template drawing in the Select a template
list.
By default this is the content of the Template folder.
- Click the Browse... button to select a template
drawing.
You can choose between *.dwg and *.dwt file types.
list.
Creating a drawing using a wizard
- On the Create New Drawing dialog box, choose Use a Wizard, then click the Next button.
- Choose between either Imperial or Metric default settings, then click the Next button.
- Select the Unit of measurement and the display Precision, then click the Next button.
- Select the Angle of measurement and the display Precision, then click the Next button.
- Choose between Color Dependent plot styles (CTB) or Named plot styles (STB), then click the Next button.
- Select the default Color and Linetype.
- Define the Grid, Snap, UCS icon and Marker Blips settings.
- Click the Finish button to create the drawing.
(option) Choose Save As.. in the File menu to save the drawing as a new template in the Templates folder.
