Scaling entities
The SCALE command resizes a selection set in relation to a base point. You can specify the scale factor by selecting a base point and a length or by typing an explicit scale factor in the Command line. The scale factor can also be defined with respect to a base scale factor. E.g. when the base scale factor is 2 and the new scale is 3, the new size is 3/2 of the original. The base scale and the new scale can also be defined graphically in the drawing.
Scaling a selection set
  1. Launch the SCALE command.
    You are prompted: Select entities to scale [selection options (?)]:
  2. Select entities.
    Entities in set: xx
  3. Select more entities or press Enter to continue.
    You are prompted: Base point:
  4. Specify a point.
    The base point is not moved in the scaling.
    You are prompted: Scale factor or [Reference/Copy] <current scale*>:
  5. Type a scale factor or press Enter to accept the previously used value.
* The previously used scale factor in a drawing is remembered.
Scaling a selection set using a reference scale
  1. Repeat steps 1 through 4 of the procedure above.
  2. Choose the Reference option.
    You are prompted: Reference scale <1>:
  3. Click the base point again (see step 3 in the previous procedure) (1).
    You are prompted: Second point:
  4. Specify a point. (2)
    The distance between the base point and the second point will be used as the reference scale.
    The selection scales dynamically.
    You are prompted: New scale factor or [Points] <2>:
  5. Do one of the following:
    • Type a value.
      The distance between the reference points is set to the specified value.
      The size of the selection set is scaled accordingly.
    • Specify a point to position the second reference point (see step 4) (3).
