Stretching entities
The size and shape of entities can be changed by stretching them. You select an area in your drawing using either a rectangular window or a polygon, then you specify a base point and a displacement point. All points and nodes inside the selected area will be moved over the specified distance. As a result, entities that cross the window or polygon boundary are stretched; those completely within the window or polygon are simply moved.
Stretching entities
- Launch the STRETCH command.
You are prompted: Select entities to stretch by [Crossing window/Crossing Polygon/Remove/Add/selection options (?)]:
- Use a crossing window (or crossing polygon) to specify the points that need to
be moved.
Specify the bottom right corner of the crossing window.
A green rectangle is dynamically displayed.
You are prompted: Opposite Corner:
- Specify the top left corner of the crossing window.
Entities in set: xx.
- Do one of the following:
- Use a crossing window (or crossing polygon) to specify the points that need to be added or removed from the selection.
- Right-click or press Enter to confirm the current selection.
You are prompted: Base point of displacement:
- Specify a point.
The selected points move with the cursor.
You are prompted: Second point of displacement:
- Specify a point to confirm the stretch distance.
