AI Assist
The AI Assist ribbon provides suggestions based on your personal BricsCAD usage, and similar users. The AI Assist tab has two states: an empty state and a populated state.
The AI Assist tab in the empty state
The AI Assist tab in the empty state when the USENEWRIBBON system variable is set to ON.
Data Settings / Sign in
The Join Usage Data Program button opens the BricsCAD Usage Data Program dialog box.
The populated state becomes available when the user signed up for the BricsCAD Usage Data Program.
The AI Assist tab in the populated state:
Data Settings
The Manage Usage Data button opens the BricsCAD Usage Data Program dialog box.
Other Command Suggestions
Displays commands used by other users with similar interest as yours.
Personal Command Suggestions
Displays the most important commands used by the user.
Note: Panels will be populated after one / two days usage of BricsCAD, and takes into consideration the commands launched from the ribbon. Also, not everyone will be eligible for all models, depending on how we categorize them.
Next Commands
Dynamically displays five predicted commands which could be used by the user after the current command.
