Layer utilities
The layer utility commands help you to easily manipulate the On/Off, Thaw/Freeze and Unlocked/Locked layer properties by selecting entities. You can then save the result in a Layer State.
The layer utility commands sit on the Layers toolbar and on the Home / Layers ribbon panel in the Drafting and Modeling workspaces.
Command Icon Description
LAYON
Turns on all layers that have been turned off.
LAYOFF
Turns off layers associated with selected entities.
LAYFRZ
Freezes layers associated with selected entities.
LAYTHW
Thaws all frozen layers.
LAYLCK
Locks layers associated with selected entities.
LAYULK
Unlocks layers associated with selected entities.
LAYISO
Isolates layers associated with selected entities. If no entity on the current layer is selected, the layer of the entity that is selected first temporarily becomes the current layer until the LAYUNISO command is executed.
LAYUNISO
Restores layers isolated by the LAYISO command.
