Zooming
The ZOOM command visually changes the size of the drawing within the current viewport.
The RTZOOM command zooms the drawing in real-time.
You can change the magnification of your drawing at any time by zooming. The cursor changes to a magnifying glass when aN RTZOOM tool is active. Zoom out to reduce the magnification so you can see more of the drawing, or zoom in to increase the magnification so you can see a portion of the drawing in greater detail. Changing the magnification of the drawing affects only the way the drawing is displayed; it has no effect on the dimensions of the entities in your drawing.
Real-time zooming
- Launch the RTZOOM command.
The shape of the cursor changes to a magnifying glass.
Hold down the left mouse button, then move the mouse.
- (option) Right-click to display a context menu.
The options are:
- Exit: exits the command.
- Pan: switches to the RTPAN command.
- Zoom: switches to the RTZOOM command.
- Constraint Sphere: switches to the RTROT command.
- Sphere: switches to the RTROTF command.
- Press the Esc key to exit the command.
Zooming to extents
Do one of the following:
- Double-click the middle mouse button (scroll wheel).
- Launch the ZOOM command, then type E and press Enter.
Dynamic zooming
Pans and zooms using a rectangular view box, representing the current viewport. The command first zooms out to display the entire drawing. You can then control the size of the view box dynamically and position the view box on the part of the drawing you want to display in the current viewport.
- Launch the ZOOM command.
- Choose the Dynamic option.
The drawing zooms out to extents.
A dashed rectangle indicates the area of the previous view.
A view box of the same size as the dashed rectangle is attached to the cursor.
- (option) To resize the view box:
- Click, then move the cursor to resize.
- Click again to stop resizing.
- Position the view box over the drawing area you want to enlarge, then
right-click.
The drawing is zoomed in on the selected area.
