BIM project info
About
For more information about this command, visit the Command reference article BIMPROJECTINFO.
Setting the project database
Open the BIM Project Info dialog box by typing BIMPROJECTINFO in the Command line and select the Project Database tab:
Project database (1) Shows the BIM project info. Project database drop-down list (2) Choose between Embedded or External. Embedded (3) Saves the project database in the drawing file. External (4) Saves the project database in a BIM database file (.bsyslib). Properties (5) Shows the properties of the BIM project e.g. region, language, and units. Statistics (6) Shows the properties, materials, compositions and profiles of the current project library of the BIM model. Custom properties (7) Adds custom properties to materials and compositions. Import (8) Imports the selected .xml and .csv library files which may add materials, compositions or profiles to the project database. Export (9) Saves .xml library files in the defined location. -
To change the project database from Embedded to External or vice versa, select the desired option in the Project Database drop-down list.
Note: The external database keeps the database independent from the current drawing. This is especially useful if you want to share the database between multiple models, e.g. when a model consists of several Xref drawings.- When switching from Embedded to
External a
File dialog displays. Do one of the following:
- Type a name in the File Name field to export the content of the project database to a new .bsyslib file, then click the Open button.
- Select an existing .bsyslib file, then click the
Open button.
The current content of the project database is merged with the selected .bsyslib file, including the imported libraries.
- When switching from External to Embedded the content of the external database is copied to the embedded project database.
External a
To specify the Project Database properties such as Region and Language, fill out the Region field and choose one of the language options in the drop-down list.
Optionally, use the custom properties button to add material and composition custom properties in the Project Database.
Press the OK button to accept it.
Setting the Central database
Click the Central Database tab in the BIM Project Info dialog box:
To select a BIM database file (.bsyslib), click the Browse (10) button of the Path field, then choose a database file in the file dialog.
Optionally, tick the Set as default (11) option to set the selected database as default library database for next projects.
Adding profiles by importing xml or csv files in the project database (.bsyslib)
- In the Project Database tab, press the Import button that opens the Select xml/csv file to import dialog box.
- Choose the XML or CSV Library files and press the Open button.
- The CSV Library files that add profiles must respect the below format:
- The first row indicates the profile shape name (AsymmetricIShape, CShape, Circle, CircleHollow, CraneRailAShape, CraneRailFShape, Ellipse, IShape, LShape, Rectangle, RectangleHollow, RoundedRectangle, Trapezium, TShape, UShape, ZShape).
Right of the general columns are the columns that indicate the specific parameters for each shapes of profiles.
Below are the shapes of profiles with the specific parameters (in bold) necessary to be indicated for a successful import. The meaning of each parameter can be better understood from the profiles preview (BIMPROFILES/New profiles).
Shape of profile | parameters | Shape of profile | parameters | |
AsymmetricIShape |
overallWidth overallDepth webThickness flangeThickness filletRadius topFlangeWidth topFlangeThickness topFlangeFilletRadius centreOfGravityInX |
LShape |
depth width thickness filletRadius edgeRadius legSlope centreOfGravityInX |
CShape |
depth width wallThickness girth internalFilletRadius centreOfGravityInX |
Rectangle |
xDim yDim |
Circle | radius | RectangleHollow |
xDim yDim wallThickness innerFilletRadius outerFilletRadius |
CircleHollow |
radius wallThickness |
RoundedRectangle |
xDim yDim roundingRadius |
CraneRailAShape |
overallHeight baseWidth2 radius headWidth headDepth2 headDepth3 webThickness baseWidth4 baseDepth1 baseDepth2 baseDepth3 centreOfGravityInY |
Trapezium |
bottomXDim topXDim yDim topXOffset |
CraneRailFShape |
overallHeight headWidth radius headDepth2 headDepth3 webThickness baseDepth1 baseDepth2 centreOfGravityInY |
TShape |
depth flangeWidth webThickness flangeThickness filletRadius flangeEdgeRadius webEdgeRadius webSlope flangeSlope centreOfGravityInY |
Ellipse |
semiAxis1 semiAxis2 |
UShape |
depth angeWidth webThickness flangeThickness filletRadius edgeRadius flangeSlope centreOfGravityInX |
IShape |
overallWidth overallDepth webThickness flangeThickness filletRadius |
ZShape |
depth flangeWidth webThickness flangeThickness filletRadius edgeRadius |
An example of such a .csv file (templates_of_mostly_used_profiles.csv) for the most used profiles is stored in your Support folder in the following path:
C:\Users\<user_name>\AppData\Roaming\Bricsys\BricsCAD\V20x64\en_US\Support\Bim\Profiles.
The Appdata folder is a hidden folder by default, you may have to unhide folders first. This path can also be accessed by the SUPPORTFOLDER command.
The project filter
You can attach any number of tags to each Physical Material or Composition. Any string can be entered as a tag.
Each of the tags can be used as a filter on the database. There is a button at the top of each list (), to switch the filter on or off. If the filter is on, only Compositions and Physical Materials that match at least one of the filter tags will be listed.
- If the project filter is empty, the button is not active (BIM Compositions panel) or is not available (Materials and Compositions editors).
- The project filter is defined, but not active.
- The project filter is defined and active.
A tooltip shows the current project filter.
Setting the project filter
Select the Filter tab page on the BIM Project Info dialog box.
Check the tags you want to use in the filter.
