Define reflected ceiling plan
Command
BIMSECTION
About
Reflected ceiling plans show a mirror image of the ceiling. These are useful to show
the layout of lights and other installations in the ceiling. To produce the
reflected ceiling plan a section is created. This section displays the part of the
building above the section boundary.
Create a reflected ceiling plan
- Select Reflected Ceiling Plan from the ribbon
or enter BIMSECTION into the Command line followed by R to
choose the Reflected ceiling option.
You are prompted: Select a point to place section:
- Select the ceiling or a face with a plane parallel to that of the ceiling.
- Do one of the following:
- Type a value in the dynamic dimension field to offset the section from the initial position.
- Left-click when the section plane is at the location you want.
- The reflected ceiling section has now been defined. To view hover over the section and select Clip display from the Quad.
- To generate the reflected ceiling plan on a sheet, hover over the section in the model and select Generate Section from the Quad.
- To open the section result drawing click Open Model. The sheet is saved to the same folder that contains the model drawing.
