Working with Point Clouds in BIM
About POINTCLOUDDETECTFLOORS
The new POINTCLOUDDETECTFLOORS command generates volume sections for each floor in a point cloud representing a building. The detection is based on regions of points with similar Z-coordinates. The generated volume sections can help navigating point clouds of buildings.
Section planes work on point clouds as well, they can be used to show parts of point clouds. The difference between point cloud crops and section planes is that point cloud crops only clip the point cloud while section planes clip all geometry in a drawing.
For more information about this command, visit the Command reference article POINTCLOUDDETECTFLOORS.
Detecting floors from point clouds
- Type POINTCLOUDDETECTFLOORS in the Command line.
- You are prompted: Operate on full point cloud or a selection?
[Full/Selection]
- Full: the command will search the entire point cloud for floors and generates a section for each of them.
- Selection: the command only runs on the selected area.
- Press Enter.
About POINTCLOUDFITPLANAR
POINTCLOUDFITPLANAR is used to semi-automatically create 3D geometry based on a point cloud scan. It will create a planar surface or solid after selecting one point in a point cloud. The points that seem to be in a plane are never exactly in one plane, therefore a threshold value is set as a property of the point cloud entity. This also works in bubble view.
For more information about this command, visit the Command reference article POINTCLOUDFITPLANAR.
Creating 3D solids from the bubble view
- Double-click a green point cloud bubble to open the Bubble viewer.
- Type POINTCLOUDFITPLANAR in the Command line.
- Select the desired wall.
- Press A to accept the selection. (Optional) Select more walls.
- Close the Bubble viewer. The surfaces are created and you can edit them to closed spaces with LCONNECT or other connecting tools.
Creating 3D entities from the model space
You can also use this command in the model space when the Bubble viewer is not open. BricsCAD will ask you to select a point of the point cloud in model space. Depending on the size of the cropped point cloud, it takes longer but it has 2 advantages by searching multiple scan positions:
- It can create larger surfaces where only parts are visible in each scan position.
- It can detect wall and slab thickness since it can take the opposite surface into account.
- Select a wall where you want to create a plane or solid.
- You are prompted: Accept, Decline, Switch Mode (contour) (CTRL)
[Accept/Decline/Mode]:
- Press A to create the wall.
- Press D to decline.
- Press M or CTRL repeatedly to switch between different modes.
Contour mode will create the best fitting plane:
Rectangular mode will create a rectangular plane around region of planar points:
Solid mode will create a solid from two parallel point cloud planes:
Note: If the point cloud exists of multiple rooms, you can use the solid mode to automatically create solid walls. - Press A to create the wall.
These solids can be the base for a more complex BIM Model. Use modeling commands to complete the building and add BIM data with Bimify, Automatch and Propagate to quickly transform your point cloud into a complete BIM Building.
It may be helpful to turn on the Point Cloud Closest Point Esnap setting. This snap setting significantly improves your ability to select relevant point cloud points.
About POINTCLOUDPROJECTSECTION
POINTCLOUDPROJECTSECTION automatically generates a raster image with optional contour lines out of a defined section box. These lines can be easily manipulated into a detailed 2D drawing.
For more information about this command, visit the Command reference article POINTCLOUDPROJECTSECTION.
Creating a raster image from a point cloud
- Type POINTCLOUDPROJECTSECTION in the Command line.
- The Command Context panel opens. Edit the options to customize your projected section. Turn the Detect walls (1) option off.
- Click Apply to generate the raster image.
Point Cloud scan by Realistic Visual styles.
Detecting walls from a point cloud and generate in 2D
Making horizontal sections from point clouds
Note: Turn on the Detect walls option (1) to generate the green lines as seen in the image below.
- Click Apply to generate the raster image..Note: If there are some missing lines, you can draw them yourself by tracing the background image.
Making vertical sections from point clouds
Make a vertical section box on the location where you want the vertical projection.
Generating BIM sections with point clouds
