Using drag
Commands
DRAG
About
The Drag tool allows you to move walls, slabs or linear elements on the highlighted face of a solid. For instance, the Drag tool can be used to move linear solids by highlighting/selecting the end or side face of a linear solid. Depending on the modeling operation, the connection between solids can be either preserved while dragging one or more solids at a time or solid (s) can be moved independently by disjoining the connectivity to other solid(s).
Procedure: using drag on a 3D solid
- Highlight/select any faces of the solid and select Drag from the tab.
- Move the cursor to adjust the position of the moving solid in the dynamic
dimension field, then click or enter a precise value in the dynamic
dimension field and press Enter.Note: A ruler appears to visually represent the distance over which you will move the entity.
- The Hotkey Assistant appears at the bottom of the screen showing the
available options.
- Select the Disable connectivity mode (default) option to move the
solid while breaking the connections between solids.In the following illustration, the solid behavior is shown before and after applying the Drag in "Disable connectivity mode". The connectivity between walls, i.e. T- (3) and L- (6) connections are disjointed after dragging an inner wall surface (5).
