Using the Bricsys 24/7 panel
About Bricsys 24/7
The Bricsys 24/7 Panel helps team members to find and share their drawings.
Bricsys 24/7 enables project management, a collaboration between project teams, cloud computing security and task automation. The big advantage of this cloud-based service is that BricsCAD® is directly linked to it by the Bricsys 24/7 Panel.
Use the Bricsys 24/7 panel in BricsCAD BIM
- Open the Bricsys 24/7 panel by clicking on the Bricsys
24/7 icon in the Tool panel on the right side of the
workspace.Note: If you do not find this icon in the Tool panel, right-click in the Tool panel and check Bricsys 24/7 in the drop-down menu, as is described in the Panels introduction article.
Log in to your 24/7 account if necessary (see Bricsys 24/7 Panel help article).
Add a file to the project
- Open a folder where you want to add the file.
- Press the plus icon that opens the Add new document and choose a file to add.
- Choose a status from the drop down list, e.g. Draft.
- Enter a description.
- Press the Upload button.
The file is displayed in the folder list files and it is Available for download. The local folder for download is defined with the CLOUDDOWNLOADPATH system variable.
The file is opened by double-clicking on it.
After editing and saving it, the status of the file is changed to Locally modified.
By right-clicking on the file, you can choose to lock it for editing by another person.
You can upload the modified file with a new status and description. The file will be marked as Up-to-date.
