Import and underlay Autodesk® Revit® files in BricsCAD
Commands
IMPORT
Disclaimer
Unless otherwise indicated, the word "Revit" used in this article refers to the Revit® software and its peripherals by Autodesk®.
About Revit import
The Revit import function allows you to import .RVT files into BricsCAD as 3D solids or as a geometry underlay for referencing purposes. However, any project data and model metadata, i.e. Constraints, Wall Type structure assembly, materials etc., from the Revit model are not imported.
You can also choose to import selected geometries by 3D Views, by Family Categories, by Levels or by View Worksets, depending on how the Revit project file has been set out.
If you import the RVT file as a solid, only the geometry will be imported with no BIM metadata attached to it. The solids can later be classified and edited with direct modelling tools in BricsCAD.
If you import the RVT file as an underlay, almost like how an XREF is used, the BricsCAD model performs faster and smoother generally. This process also takes a shorter time than importing as a solid. However, the underlay model becomes an OdRvtEntity, like a non-editable, singular block. This method is particularly useful if you are looking to import the Revit model only for reference and coordination purposes, i.e. importing a Revit structural model to look for clashes with your architectural / MEP model within BricsCAD.
BricsCAD V21 currently supports the import of Revit 2015-2020 files only. If you would like to import a model created in a later version of Revit, please consider importing the model into BricsCAD as an IFC file. For more information, please visit the IFC Import and Export in BricsCAD article.
Procedure: importing a Revit file as a solid in BricsCAD
- Open a new BricsCAD file.
- Type Import in the command-line and press Enter or click the BricsCAD icon in the ribbon and select Import to launch the Import command.
- The Import File dialog box pops up. Select Revit Project (*.rvt) in Files of type, select the file you want to import from your folder and click Open.
- You are prompted: Choose import mode as [Import/Underlay]:
Type I and Press Enter to select Import.
- You are prompted: Choose elements [All/by Views/by
Categories/by Levels/by WorkSets]:
There are different filters to import a file. Select the filter you want to use by clicking into your desired option in the command-line or by hitting their respective letters in bold.
- All
All elements present within the RVT file will be imported.
- By Views
Select a view from the View Import dialog box and the elements will be imported based on the view’s Visibility/Graphics Overrides settings in Revit. The views are structured based on their View Types.
You can expand any relevant or applicable View Type category for the specific views. It could look like this, if the 3D Views category is expanded:
Note: Importing elements via a 2D view, ie. Floor Plans etc., only brings elements that are made visible in the Visibility/Graphic Overrides in the Revit model settings for that particular view. It does not necessarily bring elements hosted onto its corresponding level, if they are made hidden on the plan view. - By Categories
You can select one or multiple built-in Categories and Element Types from the Revit Project Import dialog box. Elements of those chosen categories and element types will be imported.
- By Levels
You can select one or multiple levels from the Import By Levels dialog box. Elements hosted to the chosen levels will be imported.
- By WorkSets
You can select one or multiple worksets from the Import By Worksets dialog box.
This method of importing works best on a workshared Revit model. It is recommended you import a Central Model to ensure you are importing the latest information in the worksets. Detaching the Central Model is optional.
If you import a non-workshared Revit model, only Workset1 is available.
If you import a workshared Revit model, either Central or Local, the User-Created worksets within the model will be available in the dialog. The elements which belong to this workset will be imported.
Note: The Shared Levels and Grids and Workset1 worksets are created in Revit by default when Worksharing is enabled and can be managed by the Revit user.
- All
- If you have chosen to import by view, you do not have to specify the level of detail. The Detail Level of the selected view set in Revit will be used.
- For the rest of the other options,
you are prompted: Import Elements with Detail Level [Fine/Medium/Coarse]:
Select the level of detail you want. Type F in the command-line for fine, M for medium and C for coarse and press Enter.
Note: When selecting the level of detail, make sure you are aware of how the incoming geometries have been set out in terms of Detail Levels within the Family Elements Visibility Settings in Revit. - Select the View, Categories, Levels or WorkSets you want to import and click OK. The RVT file will be imported as 3D solid geometries.
- Now, you can classify the solid manually or automatically and/or further edit it
with direct modeling tools in BricsCAD.Note: Some of Revit’s system families, such as walls and floors etc., are imported into BricsCAD as 3D solids, where you can further manipulate their geometries directly. This also applies to Model-In-Place components and Element Types, such as Fascias, that can be defined geometrically by a Profile.
However, other system families designed with in-built constraints, i.e. stairs and curtain walls etc. are imported into BricsCAD as separate Block References. For eg., Curtain Panecl and Curtain Wall Mullion Types, which make up a Curtain Wall Type in Revit, will exist as separate Block References. This also applies to all other loadable families, like furniture, placed within the Revit model. For more information, please visit the article on Working with Blocks.
Procedure: importing a Revit file as an underlay in BricsCAD
- The Import File dialog box pops-up. Select Revit Project (*.rvt) in Files of type, select the file you want to import from your folder and click Open.
Type U and Press Enter to select Underlay.
- Follow Steps 5-7 of the ‘Procedure: importing a Revit file as a solid in BricsCAD’ above.
- You are prompted: Deviation value:
By default, the deviation value is 0.001. Press Enter to accept or type a new value and press Enter.
Note: The deviation value defines the accuracy of the imported model. A lower value will result in a finer geometry, but it will take longer time to load. - The RVT file is now imported as a non-editable OdRvtEntity.
Procedure: importing a Revit family in BricsCAD
Please refer to the article Importing Revit RFA Families in BricsCAD for more information.
Texture and graphics of the imported geometries
Although project information and element metadata in a Revit model cannot be brought into BricsCAD (just yet), there are some aspects of the imported 3D solids, i.e. Material Color, Transparency, which can be brought over and therefore correspond to the original graphics set in the Revit.
To retain the consistency of the graphical information during the import process, ensure your RGB color and transparency settings set in Revit’s Material Browser are set to your desired values.
In the example below, the values taken will be RGB 149 134 119 and 0 (%) for the colors and transparency values respectively.
If the imported element is a Revit System Family with the ability to define its structure assembly, i.e. Wall Type, and is made up of various layers of materials or functions, BricsCAD applies the color template values from the outermost materials (on both the Exterior and Interior sides) accordingly on to the corresponding geometry’s faces.
Let's take an example from the illustration below, the values will be derived from the materials assigned on Layers 1 and 9, which are Cladding... and Plaster respectively.
Otherwise, BricsCAD applies the color value, and the transparency settings if applicable, to the 3D solid replacing the respective parts of the Revit Family. This also applies to those Loadable Families and Components, having loaded into the imported Revit project.
