Bill of Materials
You can use the BMBOM, BMBOMEDIT, BMBOMPANELOPEN and BMBOMPANELCLOSE commands.
An engineering Bill of Materials (BOM) is a list of unique mechanical components, mechanical blocks and mechanical entities used in an assembly. In BricsCAD, the list is represented as a table entity and can be placed anywhere in the drawing. Each entity has its own serial number (starting with 1), name, and number of occurrences.
You can view and configure Bills of Materials in the Bills of Materials Manager.
