Bricsys Help Center
Home
Generated Drawings
BricsCAD
Installation and licensing
Installing BricsCAD
BricsCAD system requirements
下载 BricsCAD
安装选项概述
交互式安装
Silent Installation (Windows only)
试用模式
Installation process of Linux RPM package on KDE desktop environment
Activating and licensing BricsCAD
Overview of licensing options
许可证级别
许可证类型
许可证选项
BricsCAD and AutoCAD® feature comparison
Trial: online activation
Trial: offline (manual) activation
Single or volume license: online activation
Single or volume license: offline (manual) activation
Using a network license on a client computer
Setting up a network license server
Network license server
Quick guide on using a network license
Setting up a Windows network license server
Setting up a Linux license server
Network license: online activation
Network license: offline (manual) activation
Network license server administration
Advanced configurations
Managing licenses
Managing BricsCAD licenses with multiple Bricsys accounts
Modifying a BricsCAD license
Deactivating or revoking a BricsCAD license
Migrating a single or volume license to another computer
Migrating a network license to another server
License pooling
Network license usage report
Roaming
Roaming a network license on a client computer
Returning a roamed network license to the server
Proxy settings on a client computer
Getting started with BricsCAD
Launching BricsCAD
Exploring the interface
The BricsCAD application window
The Start tab
文件选项卡
Choosing the workspace
The drawing area
Look From widget
The Command line
The Status bar
菜单
工具栏
The ribbon
The Quad basics
The Quad cursor menu
Detailed settings for the Quad cursor
Right-click menus
The clean screen mode
Keyboard shortcuts
Prompt menus
Rollover tips
Working in BricsCAD
Creating a drawing
Template drawings
Drawing file format compatibility in BricsCAD
Entity creation settings
How to draw accurately
Executing commands
View control
Selecting entities
Using the Manipulator
Working with the Structure panel
Dialog boxes
About BricsCAD dialog box
Add block to library dialog box
Add button item dialog box
Add Entity Alias dialog box
Add-in manager dialog box
Add menu item dialog box
Add plot style table dialog box
Add quad button filter dialog box
Add scale dialog box
Allowed deviations from center axis dialog box
Annotation Object Scale dialog box
Array dialog box
Attach External Reference dialog box
Attach PDF underlay dialog box
Attach raster image dialog box
Attribute editor dialog box
Auto Match dialog box
Background dialog box
BIM BCF panel - Custom login dialog box
BIM project info dialog box
BIM Properties dialog box
BIM Typed Plan Editor dialog box
BIM Typed Plans dialog box
Blade - BricsCAD LISP advanced development environment dialog box
Block attribute manager dialog box
Block definition dialog box
Block Replace dialog box
Block to Xref dialog box
Boundary dialog box
Bricsys license manager dialog box
Calculator dialog box
Change dictionaries dialog box
Change Icon dialog box
Choose window style dialog box
Classify As Bim Element dialog box
Column filter dialog box
Combine Duplicate Block Definitions dialog box
Communicator info dialog box
Compare two models dialog box
Compositions dialog box
Configure Settings dialog box
Configure structure tree dialog box
Confirm deleting selected cache items dialog box
Create detail dialog box
Create new drawing dialog box
Create new sheet set dialog box
Create or edit block definition dialog box
Create Project dialog box
Create Schedule dialog box
Create section/elevation dialog box
Current Plot Style dialog box
Customization groups dialog box
Customize dialog box
Customize (Tool Palettes) dialog box
Custom properties dialog box
Custom paper sizes dialog box
DataLink edit dialog box
Datalink manager dialog box
Default scale list dialog box
Define attribute dialog box
Delete duplicate entities dialog box
Digital Signatures dialog box
Drawing explorer dialog box
Drawing explorer options dialog box
Drawing properties dialog box
Drawing view presets dialog box
Edit attributes dialog box
Edit custom properties dialog box
Edit hyperlink dialog box
Edit Quad Button Filter dialog box
Edit scale dialog box
Edit scale list dialog box
Entity grouping dialog box
eTransmit dialog box
Extract attributes dialog box
Field dialog box
Filter Configurator dialog box
Find and replace dialog box
Flatshot dialog box
Format dialog box
Geographic location dialog box
Geometric tolerance dialog box
Hatch and gradient dialog box
Hatch Edit dialog box
Import Civil 3D dialog box
Import page setups dialog box
Import sheet set dialog box
Insert block dialog box
Insert object dialog box
Insert table dialog box
Layer Property Filter dialog box
Layer settings dialog box
Layer translator dialog box
Layout manager dialog box
Links dialog box
Load application files dialog box
Load linetypes dialog box
Load Multiline Styles dialog box
Login dialog box
Manage Customizations dialog box
Map Connect dialog box
Match Properties dialog box
Mechanical Properties dialog box
Motion Path Animation dialog box
Navigate Settings dialog box
New Layer Name dialog box
New Multileader Style dialog box
New Multiline Style dialog box
New Page Setup dialog box
New Sheet(s) dialog box
Page setup dialog box
Paste special dialog box
Physical materials dialog box
Plot stamp dialog box
Plot style table editor dialog box
Plotter Configuration Editor dialog box
Point Cloud Reference Manager dialog box
Pre-process point cloud data file(s) dialog box
Print dialog box
Profiles dialog box
Project Database dialog box
Proxy information dialog box
Publish dialog box
QLeader Settings dialog box
Reassociate entity data dialog box
Reference Edit dialog box
Render dialog box
Run BricsCAD VBA macro dialog box
Save block definition dialog box
Save detail dialog box
Save workspace dialog box
Security dialog box
Security options dialog box
Select color dialog box
Select Custom Arrow Block dialog box
Select items to delete from cache dialog box
Settings dialog box
Set viewpoint dialog box
Sheet Properties dialog box
Sheet View Properties dialog box
Sheet selection sets dialog box
Sheetset setup dialog box
Spatial Locations Manager dialog box
Spell checking dialog box
Standard open file dialog box
Standard save file dialog box
Subset Properties dialog box
Table Cell Format dialog box
Tags dialog box
Tool image dialog box
Tool Properties dialog box
Upload to Bricsys 24/7 dialog box
User coordinate system dialog box
User profile manager dialog box
Validate Digital Signature dialog box
VBA manager dialog box
View Options dialog box
Visual settings dialog box
Wizard page dialog box
Working sets dialog box
Write block to file dialog box
Panels
Animation editor panel
Attachments (legacy) panel
Attachments panel
BIM BCF panel
BIM compositions panel
BIM profiles panel
BIM project browser panel
BOM manager panel
Bricsys 24/7 panel
Command panel
Command line panel
Content browser panel
Details panel
Layers panel
Layers (legacy)
Library panel
Mechanical browser panel
Parameters and constraints panel (legacy)
Parameters Manager panel
Properties panel
Render materials panel
Report panel
Sheet sets panel
Structure panel
Tips panel
Tool palettes panel
Tool Palettes (experimental) panel
Version control panel
Visibility states panel
Managing drawings
Creating a drawing
Working in the Drawing Explorer dialog box
Drawing properties
Drawing security options
Opening and saving drawings
Getting drawing information
Comparing drawings
Repairing a drawing
Projects
File Types Dictionary
Drawing accurately
Orthogonal mode
Unit settings
Coordinate reference system
2D constraints
Using dimensional constraints
Using geometric constraints
Dynamic dimensions
Nearest distance
Coordinate input
Snap and grid
Adaptive grid snap
Nudge
2D entity snaps
3D entity snaps
Polar tracking
Entity snap tracking
User coordinate systems
Dynamic UCS
Measuring
Workflow for OPTIMIZE, OVERKILL and SIMPLIFY commands
Entity snaps overview
Apparent intersection entity snap
Center entity snap
Center of a Face 3D entity snap
Endpoint entity snap
Extension entity snap
Geometric center entity snap
Insertion entity snap
Intersection entity snap
Intersection 3D entity snap
Knot 3D entity snap
Midpoint entity snap
Midpoint 3D entity snap
Nearest entity snap
Nearest 3D entity snap
Node entity snap
Parallel entity snap
Perpendicular entity snap
Perpendicular on a face 3D entity snap
Quadrant entity snap
Tangent entity snap
Vertex 3D entity snap
Viewing your drawing
View commands overview
Layer utilities
Hide and isolate entities
Redrawing and regenerating a drawing
Panning
Zooming
View manipulation using the mouse and keyboard
View rotation
The LookFrom control
Layer states
Named views
Visual styles
Model space and paper space
Model space viewports
Paper space viewports
Creating paper space viewports
Editing paper space viewports
Layouts
Generated drawing views
2D制图
Creating entities
Working with layers
Entity linetype
Entity color
Lineweight
Fill mode
Transparency
Editing entity properties
Drawing linear entities
Drawing lines
Drawing rays
Drawing infinite lines
Drawing polylines
Drawing multilines
Drawing splines
Drawing freehand sketches
Drawing circles
Drawing arcs
Drawing ellipses
Drawing rectangles
Drawing polygons
Drawing traces
Drawing donuts
Drawing solids
Drawing revision clouds
Drawing points
Drawing wipeouts
Drawing helixes
Drawing 3D polylines
Creating regions
Creating hatches and gradient fills
Editing hatches and gradient fills
3D Modeling
Direct modeling overview
Navigate in 3D
Direct modeling commands
Direct modeling operations
Design intent recognition
Working with sections
Creating solids using the EXTRUDE command
土木工具
Create a TIN Surface
TIN Surface Edit
TIN Surface Direct Modeling
Analyzing TIN Surfaces
Working with Gradings
Creating alignments
Editing alignments
Modeling a Corridor
Working with Civil points
Understanding Civil point Symbols and Labels
Working with Symbols and Labels
Understanding Civil point Leader
Creating user-defined attributes for Civil points
Creating Corridor Template Elements
Parametric modeling
Parametric modeling overview
Operations and functions in expressions
3D constraints
Suppression feature
Working with design tables
Point cloud
Working with Point Clouds
Blocks, attributes, external references and components
Creating blocks
Using Blockify
Editing blocks
Inserting blocks
Exploding blocks
2D parametric blocks
Fuzzy insert guided workflow
Dynamic blocks
Defining attributes
Working with attributes
Editing attribute definitions
Editing block attributes
Inserting blocks with attributes
Extracting attribute information
Managing Xrefs
Attaching an external reference
Working with external references
Editing blocks and external references
Working with groups
Working with underlays
Components and component inserts
Managing images and PDF files
Managing images
Image utilities
Managing PDF files
批注
Dimensions
Dimensioning tools overview
Associative dimensions
Dimension settings
Working with dimension styles
Using the dimension style tools
Creating linear dimensions
Creating angular dimensions
Creating diametrical and radial dimensions
Centerlines and center marks
Creating ordinate dimensions
Editing dimensions
Creating leaders and annotations
Creating multileaders
Adding geometric tolerances
Texts
Text system variables
Working with text styles
Creating text
Editing text
Exploding text
Finding and replacing text
Checking spelling
Working with fields
Working with tables
Annotative Entities
Annotative entities
Annotation scales
Annotative texts
Annotative hatches and gradient fills
Annotative blocks
Annotative dimensions
Annotative leaders
Customization
Startup options
BricsCAD user files
Loading and unloading CUI files
Creating a partial CUI file
Managing toolboxes
Creating toolbars
Creating menus
Creating context menus
Creating keyboard shortcuts
Customizing the Quad
Creating Custom Quad Filters
Adding tools to user interface controls
Customizing the ribbon
Working with Tool palettes
Command aliases
User profiles
Workspaces
Digitizing tablet
Express tools
Lisp
Modifying Entities
Modifying commands overview
Entity modification settings
Match properties
Grips editing
Selection methods
Quick select
Draw order
The manipulator
Moving entities
Rotating entities
Mirroring entities
Aligning entities
Changing entities
Copying entities
Making parallel copies
Arraying entities
Extending entities
Trimming entities
Lengthening entities
Selection and grip settings
Stretching entities
Scaling entities
Breaking entities
Joining entities
Chamfering entities
Filetting entities
Editing polylines
Exploding entities
Measuring entities
Dividing entities
Printing and plotting
General procedure for printing
Plotter configuration
Plot style tables
The plot styles manager
Batch plot
渲染
Using TwinMotion
Enscape integration
Rendering overview
Rendering preferences
Rendering tools
Render materials
Lights
Creating a rendered image
User feedback
Diagnostics and usage data collection
BricsCAD BIM
Getting started
Creating a BIM model
Quad cursor
Viewing entities
Selecting entities
Level of detail
Modeling techniques
BIM linear solid
BIM window create
The library panel
Connecting solids
Creating a custom window
Creating roofs
Creating slabs
Creating walls
Curtain wall
DmPushPull
Editing grids
Inserting and editing windows and doors
Mass modeling with QuickBuilding
MEP modeling
MEP flow connection points
Offset
Splitting solids
Stair tool
Structural steel
Using BIM quickdraw
Using drag
Using parametrize
Working with parameters and constraints
Building data
Analytical model
AutoComplete BIM data
Attaching compositions
BIM classify
BIM compositions
BIM data structure
BIM ply editing
BIM project info
Using Python scripts
Classification codes
Creating and editing BIM spaces
Custom properties
Customizing BIM quantities
Load bearing direction for slabs
Physical materials
Project browser
Spatial locations
Structure browser
Design assistance
Using Bimify
Using propagate
Propagate planar
Propagate linear
Propagate pattern
Propagate edges
Propagate corner
Parametrize details
Details panel
Rhino/Grasshopper integration
Interference checking
Project collaboration
BIM collaboration format (BCF) panel
Using the Bricsys 24/7 panel
IFC import and export in BricsCAD
Import Autodesk® Revit® files in BricsCAD
Importing Autodesk® Revit® families in BricsCAD
Using Xrefs
Design documentation
Annotations in 3D
BIM tags
BIM sections
Define detailed section
Define reflected ceiling plan
Elevation hatch
Templates for generated drawings
Generating drawings
Editing generated drawings
Interior elevations
Spot elevation level
Schedules
Editing data extraction definition (.dxd) files
Detailing with BimPatch
Working with Point Clouds in BIM
Working with Typed Plans
BricsCAD Mechanical
Getting started
Mechanical workspace
3D comparison
Part Design
线程功能
Part Design Methods
Sketching
Solid Modeling
Surface Modeling
Freeform Surface Modeling
Assembly Design
Bottom-up and Top-down Assembly Design
Assembly Design Commands and Tools
Component Properties
Custom properties of mechanical components
Assembly mass properties
Standard Mechanical Components
How to create a custom standard part
Piping in Assembly Design
Arrays of Components
Array Properties
Exploded Representations
Bill of Materials Manager
Bill of Materials
Multi-parametric 3D animations
Mechanical blocks, XRefs and 3D solids
钣金
Sheet Metal Design Methods
Sheet Metal Commands and Toolbars
Sheet Metal Features
Feature Coloring
Mechanical Browser for Sheet Metal
Sheet Metal Global and Feature Properties
K-factor
Bend Table
Sheet Metal Settings
Creating Flanges
Modifying Flanges
Working with Bends and Junctions
Working with Hems
Working with Tabs
Working with T-tabs and T-junctions
Working with Bevels
Creating and Splitting Lofted Bends
Bend Relief and Corner Relief Feature Operations
Working with form and rib features
Working with Hole Features
Converting to Sheet Metal and Repairing
Unfolding Sheet Metal Parts and Exporting to CAM
Associative Unfolded Representations of 3D Solids
Smart Features
Generated Drawings
Drawing Views
Drawing Annotations
Communicator for BricsCAD
BricsCAD Communicator - Getting started
BricsCAD Communicator settings
Compatibility between Communicator and BricsCAD
BricsCAD Communicator - Supported import file formats
BricsCAD Communicator - Supported export file formats
BricsCAD Shape
Introduction to BricsCAD Shape
BricsCAD Shape user interface
Basic concepts of modeling in BricsCAD Shape
Navigation in BricsCAD Shape
Components in BricsCAD Shape
Materials in BricsCAD Shape
Layers in BricsCAD Shape
Working with steel profiles
Visualization in BricsCAD Shape
Solids in BricsCAD Shape
Creating walls in BricsCAD Shape
Quickdraw in BricsCAD Shape
Creating windows and doors in BricsCAD Shape
Creating roofs in BricsCAD Shape
Command reference
+STRUCTUREPANEL command
? command
2
2DINTERSECTION command
3
三维命令
3DARRAY command
3DCOMPARE command
3DCONVERT command
3DDWF command
3DFACE command
3DINTERSECTION command
3DMESH command
3DOSNAP command
-3DOSNAP command
3DPOLY command
A
ABOUT command
ACISIN command
ACISOUT 命令
ACTIVATESECTIONVIEW command
ADDINMAN command
ADDSELECTED command
AI_BOX command
AI_CONE command
AI_CIRCTAN command
AI_CYLINDER command
AI_DISH command
AI_DOME command
AI_EDGESURF command
AI_PYRAMID command
AI_REVSURF command
AI_RULESURF command
AI_SPHERE command
AI_TABSURF 命令
AI_TORUS command
AI_WEDGE command
AIMLEADEREDITADD command
AIMLEADEREDITREMOVE command
AIDIMFLIPARROW command
AIDIMPREC command
AIDIMSTYLE command
ALIGN command
ALIGNMENT command
ALIGNMENT3D command
ALIGNMENTCURVE command
ALIGNMENTEDIT command
ALIGNMENTELEMENTBETWEEN command
ALIGNMENTELEMENTFROM command
ALIGNMENTLINE command
ALIGNMENTVIEW command
ALIGNMENTVERTICAL command
ALIGNSPACE command
AMSURFSYM command
AMWELDSYM command
ANIMATIONEDITORCLOSE command
ANIMATIONEDITOROPEN command
ANIMATIONEDITORPLAYBACK command
ANIMATIONEDITORRECORD command
ANIPATH command
ANNORESET command
ANNOUPDATE command
APPARENT command
APPLOAD command
ARC command
AREA command
ARRANGE command
ARRAY command
-ARRAY command
ARRAYCLASSIC command
ARRAYCLOSE command
-ARRAYCLOSE command
ARRAYEDIT command
ARRAYEDITEXT command
ARRAYPATH command
ARRAYPOLAR command
ARRAYRECT command
ATTACHMENTSPANELCLOSE command
ATTACHMENTSPANELOPEN command
ATTDEF command
-ATTDEF command
ATTDISP command
ATTEDIT command
ATTEXT command
-ATTEXT command
ATTREDEF command
ATTSYNC command
AUDIT command
AUTOCOMPLETE command
AUTOCONSTRAIN command
B
BACKGROUND command
BASE command
BATTMAN command
BCLOSE command
BEDIT command
-BEDIT 命令
BHATCH command
-BHATCH command
BIMADDECCENTRICITY command
BIMALIGNSECTIONBLOCKS command
BIMANALYTICALMODEL command
BIMAPPLYPROFILE 命令
BIMATTACHCOMPOSITION command
BIMATTACHSPATIALLOCATION command
BIMAUTOMATCH command
BIMCLASSIFY command
BIMCOPY 命令
BIMCREATEDETAIL command
BIMCURTAINWALL command
BIMDECOMPOSE command
BIMDIMENSION command
BIMFLIP command
BIMFLOWCONNECT command
BIMGRID command
BIMIFY command
-BIMINSERT command
BIMINSERT command
BIMINVERTSPACES command
BIMLINEARSOLID command
BIMLIST command
BIMMULTISELECT command
BIMPARAMETRIZEDETAIL command
BIMPATCH command
BIMPROFILES command
BIMPROJECTINFO command
BIMPROPAGATE command
BIMPROPAGATECORNER command
BIMPROPAGATEEDGES command
BIMPROPAGATEFROMFILE command
-BIMPROPAGATEFROMFILE command
BIMPROPAGATELINEAR command
BIMPROPAGATEPATTERN command
BIMPROPAGATEPLANAR command
BIMPROPERTIES command
BIMPYTHON command
BIMQUICKBUILDING command
BIMQUICKDRAW command
BIMREASSOCIATE command
BIMRECALCULATEAXIS command
BIMROOM command
BIMSECTION command
BIMSECTIONOPEN command
BIMSECTIONUPDATE command
BIMSETLOADBEARINGDIRECTION command
BIMSETREFERENCEFACE command
BIMSPACE command
BIMSPATIALLOCATIONS command
BIMSPLIT command
BIMSTAIR command
BIMSTRETCH command
BIMSTRUCTURALCONNECT command
BIMTAG command
BIMUPDATESPACE command
BIMUPDATETHICKNESS command
BIMWINDOWCREATE command
-BIMWINDOWCREATE command
BIMWINDOWUPDATE command
BLADE command
BLCOMPOSITIONS command
BLIPMODE command
BLMATERIALS command
BLOCK command
-BLOCK command
BLOCKICON 命令
BLOCKIFY command
BLOCKREPLACE command
-BLOCKREPLACE command
BLOCKTOXREF command
-BLOCKTOXREF command
BMBALLOON command
BMBOM command
BMBOMEDIT command
BMBOMPANELCLOSE command
BMBOMPANELOPEN command
BMCONNECT command
BMCONVERT command
BMCREATECOMPONENT command
-BMCREATECOMPONENT command
BMDEPENDENCIES command
BMDISSOLVE command
BMEXPLODE command
BMEXPLODEMOVE command
BMEXPLODESTEPEDIT command
BMEXTERNALIZE command
BMFORM command
BMHARDWARE command
-BMHARDWARE command
BMHIDE command
BMINSERT command
-BMINSERT command
BMLINK command
BMLOCALIZE command
BMMASSPROP command
BMMECH command
BMNEW command
BMOPEN command
BMOPENCOPY command
-BMPARAMETERS command
BMPROPERTIES 命令
BMPOUT command
BMRECOVER command
BMREPLACE command
BMSHOW command
BMTRAILINGLINES command
BMUNLINK 命令
BMUNMECH command
BMUPDATE command
BMVSTYLE command
BMXCONVERT 命令
BOUNDARY command
-BOUNDARY command
BOX command
BREAK command
BROWSER command
BSAVEAS command
C
CAL command
CALLOUT command
CAMERA command
CENTER 命令
CENTERDISASSOCIATE command
CENTERLINE command
CENTERMARK command
CENTERREASSOCIATE command
CENTERRESET command
CHAMFER command
CHANGE command
CHECKSTANDARDS command
CHPROP command
CHSPACE command
CIRCLE command
CIVIL3DIMPORT command
CIVILDWGEXPORT command
CIVILPOINT command
CIVILPOINTATTRIBUTES command
CIVILPOINTGROUP command
CIVILPOINTGROUPEDIT 命令
CLEANSCREENOFF command
CLEANSCREENON command
CLEANUNUSEDVARIABLES command
CLIPDISPLAY command
CLOSE command
COLOR command
-COLOR command
命令行命令
COMMANDLINEHIDE 命令
COMMANDS command
COMMUNICATORINFO command
COMPONENTSPANELCLOSE command
COMPONENTSPANELOPEN command
CONE command
CONSTRAINTBAR command
CONTENTBROWSERCLOSE command
CONTENTBROWSEROPEN command
CONVERTCTB command
CONVERTPOLY command
CONVERTPSTYLES command
CONVTOMESH command
CONVTOSOLID command
CONVTOSURFACE command
COPY command
COPYBASE command
COPYCLIP command
COPYEDATA command
COPYGUIDED command
COPYGUIDED3D command
COPYHIST command
COPYTOLAYER command
CORRIDOR command
CORRIDOREDIT command
CORRIDOREXTRACT command
CORRIDORTEMPLATE command
CORRIDORTEMPLATEELEMENT 命令
CORRIDORTEMPLATEELEMENTEDIT command
CPAGESETUP command
CREATELIBRARYBLOCK command
-CREATELIBRARYBLOCK command
CREATETHUMBNAIL command
GUILOAD 命令
CUIUNLOAD command
CUSTOMIZE command
CUTCLIP command
CYLINDER command
D
数据提取命令
-DATAEXTRACTION command
DATALINK command
DATALINKUPDATE command
DATASMITHCONNECT command
DATASMITHEXPORT command
DATASMITHSYNC command
DBLIST command
DCALIGNED command
DCANGULAR command
DCCONVERT command
DCDIAMETER command
DCDISPLAY command
DCHORIZONTAL command
DCLINEAR command
DCRADIUS command
DCVERTICAL command
DDATTE command
DDEDIT command
DDEMODES command
DDFILTER command
DDGRIPS command
DDPTYPE command
DDSELECT command
DDSETVAR command
DDSTRACK command
DDVPOINT command
DEFAULTSCALELIST command
DELAY 命令
DELCONSTRAINT command
DELEDATA command
DESIGNTABLE command
-DESIGNTABLEEDIT command
DETAILSPANELCLOSE command
DETAILSPANELOPEN command
DGNEXPORT command
-DGNEXPORT command
DGNIMPORT command
DGNIMPORTOPTIONS command
DIGITALSIGN command
DIM command
DIM1 Command
DIMALIGNED command
DIMANGULAR command
DIMARC command
DIMBASELINE command
DIMBREAK command
DIMCENTER command
DIMCONSTRAINT command
DIMCONTINUE command
DIMDIAMETER command
DIMDISASSOCIATE command
DIMEDIT command
DIMLEADER command
DIMLINEAR command
DIMORDINATE command
DIMOVERRIDE command
DIMRADIUS command
DIMREASSOCIATE command
DIMREGEN command
DIMSTYLE command
-DIMSTYLE command
DIMSTYLESET command
DIMTEDIT command
DISH command
DIST command
DISTANTLIGHT command
DIVIDE command
DMANGLE3D command
DMAUDIT command
DMAUDITALL command
DMCHAMFER command
DMCOINCIDENT3D command
DMCONCENTRIC3D command
DMCONSTRAINT3D command
DMCOPYFACES command
DMDEFORMCURVE command
DMDEFORMMOVE command
DMDEFORMPOINT command
DMDELETE command
DMDISTANCE3D command
DMEXTRUDE command
DMFILLET command
DMFIX3D command
DMGROUP command
DMMOVE command
DMPARALLEL3D command
DMPATH3D 命令
DMPERPENDICULAR3D command
DMPUSHPULL command
DMRADIUS3D command
DMREPAIR command
DMREVOLVE command
DMRIGIDSET3D command
DMROTATE command
DMSELECT command
DMSELECTEDGES command
DMSIMPLIFY command
DMSIMPLIFYALL command
DMSTITCH command
DMTANGENT3D命令
DMTHICKEN command
DMTHREAD command
DMTWIST command
DMUPDATE command
DOME command
DONUT command
DRAG command
DRAGMODE command
DRAWORDER command
DRAWORDERBYLAYER command
DSETTINGS command
DTEXT command
DUMPSTATE command
DVIEW command
DWFOUT command
DWGCODEPAGE command
DWGCOMPARE command
DWGPROPS command
DXFIN command
DXFOUT command
E
EATTEDIT command
EDGESURF command
EDITEDATA command
ELEV command
ELLIPSE command
ENABLEASSOCVIEWS 命令
ENDCOMPARE command
ENDPOINT command
ERASE command
ETRANSMIT command
-ETRANSMIT command
EXECUTETOOL command
EXPBLOCKS command
EXPFOLDERS command
EXPIMAGES command
EXPLAYERS 命令
EXPLODE command
EXPLORER command
EXPORT command
EXPORTLAYOUT command
EXPORTPDF command
EXPPDFS command
EXPUCS command
EXPXREFS command
EXTEND command
EXTENSION 命令
EXTRACTBLOCKS command
EXTRUDE command
F
FBXEXPORT command
-FBXEXPORT command
FIELD command
FILEOPEN command
FILES command
FILL command
FILLET command
FIND command
FITARC command
FITLINE command
FITPOLYLINE command
FLATSHOT command
FLATTEN command
FLIPLINE command
FROM command
G
GCCOINCIDENT command
GCCOLINEAR command
GCCONCENTRIC command
GCENTER command
GCEQUAL command
GCFIX command
GCHORIZONTAL command
GCPARALLEL command
GCPERPENDICULAR command
GCSMOOTH command
GCSYMMETRIC command
GCTANGENT command
GCVERTICAL command
GENERATEBOUNDARY command
GEOGRAPHICLOCATION command
GEOIMPORT command
GEOMCONSTRAINT command
GOTOSTART command
GRADIENT command
-GRADIENT command
GRADIENTBKGOFF command
GRADIENTBKGON command
GRADING command
GRADINGBALANCE command
GRAPHICOVERRIDE command
GRAPHSCR command
GRID command
GROUP command
-GROUP command
H
HATCH command
-HATCH command
HATCHEDIT Command
-HATCHEDIT command
HATCHEDITEXT 命令
HATCHGENERATEBOUNDARY command
HATCHTOBACK command
HELIX command
HELP command
HELPSEARCH command
HIDE 命令
HIDEOBJECTS command
HYPERLINK command
-HYPERLINK command
HYPERLINKOPTIONS command
I
ID command
IEMBED command
IFCEXPORT command
IMAGE command
IMAGEADJUST command
-IMAGEATTACH command
IMAGEATTACH command
IMAGECLIP command
IMAGEFRAME command
IMAGEQUALITY command
-IMPORT command
IMPORT command
IMPRINT command
INSERT command
-INSERT command
INSERTALIGNED command
INSERTION command
INSERTOBJ command
INTERFERE command
-INTERFERE command
INTERSECT command
ISAVEAS command
ISOLATEOBJECTS command
ISOPLANE command
IUNEMBED 命令
J
JOIN command
K
KEEPME command
L
LANDXMLEXPORT command
LANDXMLIMPORT command
LAYCUR command
-LAYER command
图层命令
LAYERP 命令
LAYERSPANELCLOSE command
LAYERSPANELOPEN command
LAYERSTATE command
LAYFRZ command
LAYISO command
LAYLCK command
LAYMCUR command
LAYOFF command
LAYON command
LAYOUT command
LAYOUTMANAGER command
LAYTHW command
LAYTRANS command
LAYULK command
LAYUNISO command
LCONNECT command
LEADER command
LENGTHEN command
LIBRARYPANELCLOSE 命令
LIBRARYPANELOPEN command
LICENSEMANAGER command
LIGHT command
LIGHTLIST command
LIMITS command
LINE command
-LINETYPE command
LINETYPE command
LIST command
LIVESECTION command
LOAD command
LOFT command
LOGFILEOFF command
LOGFILEON command
-LOGIN command
-LOGOUT command
LOOKFROM command
LWEIGHT command
M
MAIL command
MANIPULATE command
MAPCONNECT command
MAPTRIM command
MASSPROP command
MATBROWSERCLOSE command
MATBROWSEROPEN command
MATCHPERSPECTIVE command
MATCHPROP command
MATERIALASSIGN command
MATERIALMAP command
MATERIALS command
MATLIB command
MEASURE command
MECHANICALBROWSERCLOSE command
MECHANICALBROWSEROPEN command
MENU command
MENULOAD command
MENUUNLOAD command
MIDPOINT command
MINSERT command
MIRROR command
MIRROR3D command
MLEADER command
MLEADERALIGN command
MLEADERCOLLECT command
MLEADEREDIT 命令
MLEADEREDITEXT command
MLEADERSTYLE command
MLINE command
MLSTYLE command
MODELERPROPERTIES command
-MODELERPROPERTIES command
MOVE command
MOVEEDATA command
MOVEGUIDED command
MSLIDE command
MSPACE command
MTEXT command
-MTEXT command
MTP command
MULTIPLE command
MVIEW command
MVSETUP command
N
NAVIGATE command
NEAREST command
NETLOAD 命令
创建指令
NEWSHEETSET 命令
NEWWIZ command
NODE command
NONE command
NUMBER command
O
OBJECTSCALE command
-OBJECTSCALE command
OFFSET command
OLELINKS command
OLEOPEN command
ONWEB command
OOPS command
OPEN command
OPENSHEETSET command
-OPENSHEETSET command
OPTIMIZE command
OPTIONS command
ORTHOGONAL command
OSNAP command
-OSNAP command
OVERKILL command
-OVERKILL command
P
PACKAGE command
PAGESETUP command
PAN command
-PAN command
PANELIZE command
PARALLEL command
-PARAMETERS command
PARAMETERSPANELCLOSE command
PARAMETERSPANELOPEN command
PARAMETRICBLOCKIFY command
PARAMETRICSTRETCH command
PARAMETRIZE command
PARAMETRIZE2D command
PASTEBLOCK command
PASTECLIP command
PASTEORIG command
PASTESPEC command
PDF command
PDFADJUST command
PDFATTACH command
-PDFATTACH command
PDFCLIP command
PDFIMPORT command
-PDFIMPORT command
PDFLAYERS command
PDFOPTIONS 命令
PEDIT command
PEDITEXT command
PFACE command
PLACEVIEW command
PLAN command
PLINE command
PLOT command
-PLOT command
PLOTSTAMP 命令
PLOTSTYLE command
PLOTTERMANAGER command
PNGOUT command
POINT command
POINTCLOUD command
POINTCLOUDALIGN command
POINTCLOUDATTACH command
-POINTCLOUDATTACH command
POINTCLOUDCOLORMAP command
POINTCLOUDCOMPRESS command
POINTCLOUDCROP command
POINTCLOUDCROPSOLID command
POINTCLOUDDECOMPRESS command
POINTCLOUDDELETEITEM command
POINTCLOUDDETECTFLOORS command
POINTCLOUDDEVIATION command
POINTCLOUDEXPORT command
POINTCLOUDFITCYLINDER 命令
POINTCLOUDFITPLANAR command
POINTCLOUDGEOGRAPHICLOCATION command
POINTCLOUDIMPORT command
POINTCLOUDPOINTSIZE_MINUS command
POINTCLOUDPOINTSIZE_PLUS command
POINTCLOUDPREPROCESS command
-POINTCLOUDPREPROCESS command
POINTCLOUDPROJECTSECTION command
POINTCLOUDREFERENCE command
POINTCLOUDSHOWBUBBLES command
POINTCLOUDUNCROP command
POINTLIGHT command
POLYGON command
POLYSOLID command
PREVIEW command
PRINT command
PROFILEMANAGER 命令
PROJECTGEOMETRY command
PROPERTIES command
PROPERTIESCLOSE command
PROXYINFO command
PSETUPIN command
-PSETUPIN command
PSPACE command
PUBLISH command
-PUBLISH command
PURGE command
-PURGE command
PYRAMID command
Q
QLEADER command
QNEW command
QPRINT command
QRTEXT command
QSAVE command
QSELECT command
QRLEADER command
QTEXT command
QUADRANT command
QUIT command
R
RAY command
REASSOCAPP command
RECOVER command
RECOVERALL command
RECSCRIPT command
RECTANG command
REDEFINE command
REDO command
REDRAW command
REDRAWALL command
REDSDKINFO command
REFCLOSE command
REFEDIT command
-REFEDIT command
REFERENCECURVES command
REFSET command
REGEN command
REGENALL command
REGENAUTO command
REGION command
REINIT command
RENAME command
-RENAME 命令
RENDER command
-RENDER command
RENDERPRESETS command
RENDERWINCLOSE command
REPORTPANELCLOSE command
REPORTPANELOPEN 命令
RESETASSOCVIEWS command
RESETBLOCK command
RESUME command
REVCLOUD command
REVOLVE command
REVSURF command
RIBBON command
RIBBONCLOSE command
ROTATE command
ROTATE3D command
RSCRIPT command
RTLOOK command
RTPAN command
RTROT command
RTROTCTR command
RTROTF command
RTROTX command
RTROTY command
RTROTZ command
RTUPDOWN command
RTWALK command
RTZOOM command
RULESURF command
S
SAVE command
SAVEALL command
SAVEAS command
SAVEASR12 Command
SAVEFILEFOLDER command
SCALE command
SCALELISTEDIT command
-SCALELISTEDIT command
SCREENSHOT command
SCRIPT command
SCROLLBAR 命令
SECTION command
SECTIONPLANE command
SECTIONPLANESETTINGS command
SECTIONPLANETOBLOCK command
SECURITY command
SECURITYOPTIONS 命令
SELECT command
SELECTALIGNEDFACES command
SELECTALIGNEDSOLIDS command
SELECTCONNECTEDFACES command
SELECTCONNECTEDSOLIDS command
SELECTSIMILAR command
SELGRIPS command
SETBYLAYER command
-SETBYLAYER command
SETLICENSELEVEL command
SETTINGS command
SETTINGSSEARCH command
SETUlightCS 命令
SETVAR command
SHADE command
SHADEMODE command
-SHADEMODE command
SHAPE command
SHEETSET command
SHEETSETHIDE command
SHELL command
SIGVALIDATE command
SIMPLIFY command
SINGLETON command
SKETCH command
SLICE command
SMASSEMBLYEXPORT command
SMBEAD command
SMBEND command
SMBENDCREATE 命令
SMBENDSWITCH command
SMCONVERT command
SMDELETE command
SMDISSOLVE command
SMEXPLODE command
SMEXPORT2D command
SMEXPORTOSM command
SMEXTRUDE command
SMFLANGE command
SMFLANGEBASE command
SMFLANGEBEND command
SMFLANGECONNECT 命令
SMFLANGECONTOUR command
SMFLANGEEDGE command
SMFLANGEROTATE command
SMFLIP command
SMFORM command
SMHEM command
SMHEMCREATE 命令
SMIMPRINT command
SMJOG command
SMJUNCTION command
SMJUNCTIONCREATE command
SMJUNCTIONSWITCH command
SMLOFT command
SMPARAMETRIZE command
SMQUICK command
SMRELIEF command
SMRELIEFCREATE command
SMRELIEFSWITCH command
SMREPAIR command
SMREPLACE command
SMRIBCREATE 指令
SMROLLEDEDGE command
SMROTATE command
SMSELECT command
SMSPLIT command
SMTAB command
SMTABCREATE command
SMUNFOLD command
SNAP command
SOLID command
SOLIDEDIT command
SOLPROF command
SPELL command
SPHERE command
SPLINE command
SPLINEDIT command
SPOTLIGHT command
STANDARDPARTSPANELCLOSE command
STANDARDPARTSPANELOPEN command
STANDARDS command
STATBAR command
STATUS command
STLOUT command
STOPSCRIPT command
STRETCH command
STRUCTUREPANELCLOSE command
STYLE command
-STYLE command
STYLESMANAGER command
SUBTRACT command
SUNPROPERTIES command
SUPPORTFOLDER command
SUPPRESS command
SVGOPTIONS 命令
SWEEP command
SYSWINDOWS command
T
TABLE command
-TABLE command
TABLEDIT command
TABLEEXPORT command
TABLEMOD command
TABLESTYLE command
TABLET command
TABSURF command
TANGENT command
TCONNECT command
TEMPLATEFOLDER command
TEXT command
-TEXT 命令
TEXTSCR command
TEXTTOFRONT command
TIME command
TIN command
TINASSIGNIMAGE command
TINEDIT
TINEXTRACT command
TINMERGE command
TINMODIFY command
TINPROJECT command
TINSERT command
TINVOLUME command
TINWATERDROP command
TOLERANCE command
TOOLBAR command
-TOOLBAR command
TOOLPALETTES command
TOOLPALETTESCLOSE command
-TOOLPANEL command
TORUS command
TPNAVIGATE command
TRACE command
TRANSPARENCY command
TRIM command
TXT2MTXT command
TXTEXP command
TYPEDPLANS command
U
U command
UCS command
UCSICON command
UNDEFINE command
UNDO command
UNDOENT command
UNGROUP command
UNION command
UNISOLATEOBJECTS command
UNITS command
-UNITS command
UPDATEFIELD command
URL command
V
VBAIDE command
VBALOAD command
-VBALOAD command
VBAMAN command
VBANEW command
VBARUN command
-VBARUN command
VBASECURITY command
VBAUNLOAD command
VERSIONCONTROL command
VIEW command
-VIEW command
VIEWBASE command
VIEWBREAK command
VIEWDETAIL command
VIEWDETAILSTYLE command
VIEWEDIT command
VIEWEXPORT command
VIEWHORIZONTAL command
VIEWLABEL command
VIEWPOINT command
VIEWPROJ command
VIEWRES command
VIEWSECTION command
VIEWSECTIONSTYLE command
VIEWUPDATE command
VISIBILITYSTATES command
VISIBILITYSTATESADD command
VISIBILITYSTATESHIDE command
VISIBILITYSTATESPANELCLOSE 命令
VISIBILITYSTATESPANELOPEN command
VISIBILITYSTATESREMOVE command
VISIBILITYSTATESSHOW command
VISIBLE command
VISUALSTYLES command
-VISUALSTYLES command
VLIDE command
VMLOUT command
VPCLIP command
VPLAYER command
VPMAX command
VPMIN command
VPOINT command
VPORTS command
-VPORTS command
VSCURRENT command
VSLIDE command
VTOPTIONS command
W
WBLOCK command
-WBLOCK command
WCASCADE command
WCLOSE command
WCLOSEALL command
WEBLIGHT command
WEDGE command
WHOHAS command
WHTILE command
WIARRANGE command
WIPEOUT command
WMFOUT command
WNEXT command
WORKSETS command
WORKSPACE command
WPREV command
WSSAVE command
WSSETTINGS command
WVTILED 命令
X
XATTACH command
XCLIP command
XEDGES command
XFACES command
XLINE command
XOPEN command
XPLODE command
XREF command
-XREF command
Y
Z
ZCENTER command
ZINTERSECTION command
ZKNOT command
ZMIDPOINT command
ZNEAREST command
ZNONE command
ZOOM command
ZPERPENDICULAR command
ZVERTEX command
System variable reference
_
_QUADTABFLAGS system variable
_VERNUM system variable
3
3DCOMPAREMODE system variable
3DOSMODE system variable
3DSNAPMARKERCOLOR system variable
A
ACADLSPASDOC system variable
ACADPREFIX system variable
ACADVER system variable
ACISHLRRESOLUTION system variable
ACISOUTVER system variable
ADAPTIVEGRIDSTEPSIZE system variable
AFLAGS system variable
ALLOWBREAKLINECROSSINGS system variable
ALLOWEDBENDANGLES system variable
ALLOWTABEXTERNALMOVE system variable
ALLOWTABMOVE system variable
ALLOWTABSPLIT system variable
AMEXPORTFORMAT system variable
ANGBASE system variable
ANGDIR system variable
ANGLESAMPLINGINTERVAL system variable
ANNOALLVISIBLE system variable
ANNOAUTOSCALE system variable
ANNOTATIVEDWG system variable
ANTIALIASRENDER system variable
ANTIALIASSCREEN system variable
APBOX system variable
APERTURE system variable
ARCTESSELLATION system variable
ARCTESSELLATIONGRADING system variable
ARCTESSELLATIONTEMPLATEELEMENT system variable
AREA system variable
AREAPREC system variable
AREAUNITS system variable
ARRAYASSOCIATIVITY system variable
ARRAYEDITSTATE system variable
ARRAYTYPE system variable
CIVILASSOCIATIVITY system variable
ATTDIA system variable
ATTMODE system variable
ATTRACTIONDISTANCE system variable
ATTREQ system variable
AUDITCTL system variable
AUDITERRORCOUNT system variable
AUPREC system variable
AUTOADOPTSIZES system variable
AUTOCOMPLETEDELAY system variable
AUTOCOMPLETEMODE system variable
AUTOFLIPQUARTERTURN system variable
AUTOMATICCONNECTION system variable
AUTOMATICTEES system variable
AUTOMENULOAD system variable
AUTORESETSCALES system variable
AUTOSAVECHECKSONLYFIRSTBITDBMOD system variable
AUTOSNAP system variable
AUTOTRACKINGVECCOLOR system variable
AUTOVPFITTING system variable
B
BACKGROUNDPLOT system variable
BACKZ system variable
BASEFILE system variable
BCFSOURCEURL system variable
BILLOFMATERIALSSETTINGS system variable
BIMACTIVATEPYTHON system variable
BIMDEFAULTPROPERTIESPATH system variable
BIMMATCHPROP system variable
BIMOSMODE system variable
BIMPROFILESTANDARDS system variable
BINDTYPE system variable
BKGCOLOR system variable
BKGCOLORPS system variable
BLIPMODE system variable
BLOCKEDITLOCK system variable
BLOCKEDITOR system variable
BLOCKIFYMODE system variable
BLOCKIFYTOLERANCE system variable
BLOCKLEVELOFDETAIL system variable
BLOCKSPATH system variable
BMAUTOUPDATE system variable
BMFORMTEMPLATEPATH system variable
BMUPDATEMODE system variable
BOMTEMPLATE system variable
BOMTHUMBNAILHEIGHT system variable
BOMTHUMBNAILWIDTH system variable
BOUNDARYCOLOR system variable
BSYSLIBCOPYOVERWRITE system variable
BVMODE system variable
C
CACHELAYOUT system variable
CAMERADISPLAY system variable
CAMERAHEIGHT system variable
CANNOSCALE system variable
CANNOSCALEVALUE system variable
CDATE system variable
CECOLOR system variable
CELTSCALE system variable
CELTYPE system variable
CELWEIGHT system variable
CENTERCROSSGAP system variable
CENTERCROSSSIZE system variable
CENTEREXE system variable
CENTERLAYER system variable
CENTERLTSCALE system variable
CENTERLTYPE system variable
CENTERLTYPEFILE system variable
CENTERMARKEXE system variable
CETRANSPARENCY system variable
CHAMFERA system variable
CHAMFERB system variable
CHAMFERC system variable
CHAMFERD system variable
CHAMMODE system variable
CHECKDWLPRESENCE system variable
CIRCLERAD system variable
CLAYER system variable
CLEANSCREENOPTIONS system variable
CLEANSCREENSTATE system variable
CLIPBOARDFORMAT system variable
CLIPBOARDFORMATS system variable
CLIPROMPTLINES system variable
CLISTATE system variable
CLOSECHECKSONLYFIRSTBITDBMOD system variable
CLOUDDOWNLOADPATH system variable
CLOUDLOG system variable
CLOUDLOGVERBOSE system variable
CLOUDONMODIFIED system variable
CLOUDSERVER system variable
CLOUDTEMPFOLDER system variable
CLOUDUPLOADDEPENDENCIES system variable
CMATERIAL system variable
CMDACTIVE system variable
CMDDIA system variable
CMDECHO system variable
CMDLINEEDITBGCOLOR system variable
CMDLINEEDITFGCOLOR system variable
CMDLINEFADINGLOGBGCOLOR system variable
CMDLINEFADINGLOGFADEDELAY system variable
CMDLINEFADINGLOGFGCOLOR system variable
CMDLINEFADINGLOGTRANSPARENCY system variable
CMDLINEFONTNAME system variable
CMDLINEFONTSIZE system variable
CMDLINEFRAMEACTIVETRANSPARENCY system variable
CMDLINEFRAMEINACTIVETRANSPARENCY system variable
CMDLINELISTBGCOLOR system variable
CMDLINELISTFGCOLOR system variable
CMDLINEOPTIONBGCOLOR system variable
CMDLINEOPTIONSHORTCUTCOLOR system variable
CMDLINEUSENEWFRAME system variable
CMDLNTEXT system variable
CMDNAMES system variable
CMLEADERSTYLE system variable
CMLJUST system variable
CMLSCALE system variable
CMLSTYLE system variable
CMPCLRMISS system variable
CMPCLRMOD1 system variable
CMPCLRMOD2 system variable
CMPCLRNEW system variable
CMPDIFFLIMIT system variable
CMPFADECTL system variable
CMPLOG system variable
COLORBOOKPATH system variable
COLORTHEME system variable
COLORX system variable
COLORY system variable
COLORZ system variable
COMACADCOMPATIBILITY system variable
COMBINETEXTMODE system variable
COMMUNICATORBACKGROUNDMODE system variable
COMPASS system variable
COMPONENTSCONFIG system variable
COMPONENTSPATH system variable
CONSTRAINTBARDISPLAY system variable
CONTINUOUSMOTION system variable
CONVERTODMAX system variable
CONVERTODMIN system variable
CONVERTTHMAX system variable
CONVERTTHMIN system variable
COORDS system variable
COPYMODE system variable
CPLOTSTYLE system variable
CPROFILE system variable
CREATETHUMBNAILONTHEFLY system variable
CREATEVIEWPORTS system variable
CROSSHAIRDRAWMODE system variable
CROSSINGAREACOLOR system variable
CTAB system variable
CTABLESTYLE system variable
CTRL3DMOUSE system variable
CTRLMOUSE system variable
CURSORSIZE system variable
CVPORT system variable
CVERSIONCONTROLPATH system variable
CLOUDSSOSCOPE system variable
CLOUDSSOCLIENTID system variable
CTRLMBUTTON system variable
D
DATACOLLECTION system variable
DATACOLLECTIONENABLED system variable
DATALINKNOTIFY system variable
DBCSTATE system variable
DBLCLKEDIT system variable
DCTCUST system variable
DCTMAIN system variable
DEFAULTBSYSLIBIMPERIAL system variable
DEFAULTBSYSLIBMETRIC system variable
DEFAULTCURVETYPEHA system variable
DEFAULTCURVETYPEVA system variable
DEFAULTLIGHTING system variable
DEFAULTLIGHTSHADOWBLUR system variable
DEFAULTNEWSHEETTEMPLATE system variable
DEFAULTSPACEHEIGHT system variable
DEFAULTSTYLEPIPECROSS system variable
DEFAULTSTYLEPIPEECCENTRICREDUCER system variable
DEFAULTSTYLEPIPEELBOW45 system variable
DEFAULTSTYLEPIPEELBOW90 system variable
DEFAULTSTYLEPIPEREDUCER system variable
DEFAULTSTYLEPIPESEGMENT system variable
DEFAULTSTYLEPIPETEE system variable
DEFLPLSTYLE system variable
DEFPLSTYLE system variable
DELETEINTERFERENCE system variable
DELETETOOL system variable
DELOBJ system variable
DEMANDLOAD system variable
DETAILSPATH system variable
DGNEXPXREFMODE system variable
DGNFRAME system variable
DGNIMP2DCLOSEDBSPLINECURVEIMPORTMODE system variable
DGNIMP2DELLIPSEIMPORTMODE system variable
DGNIMP2DSHAPEIMPORTMODE system variable
DGNIMP3DCLOSEDBSPLINECURVEIMPORTMODE system variable
DGNIMP3DELLIPSEIMPORTMODE system variable
DGNIMP3DOBJECTIMPORTMODE system variable
DGNIMP3DSHAPEIMPORTMODE system variable
DGNIMPBREAKDIMENSIONASSOCIATION system variable
DGNIMPCONVERTDGNCOLORINDICESTOTRUECOLORS system variable
DGNIMPCONVERTEMPTYDATAFIELDSTOSPACES system variable
DGNIMPERASEUNUSEDRESOURCES system variable
DGNIMPEXPLODETEXTNODES system variable
DGNIMPIMPORTACTIVEMODELTOMODELSPACE system variable
DGNIMPIMPORTINVISIBLEELEMENTS system variable
DGNIMPIMPORTPAPERSPACEMODELS system variable
DGNIMPIMPORTVIEWINDEX system variable
DGNIMPRECOMPUTEDIMENSIONSAFTERIMPORT system variable
DGNIMPSYMBOLRESOURCEFILES system variable
DGNIMPXREFIMPORTMODE system variable
DGNOSNAP system variable
DIASTAT system variable
DIMADEC system variable
DIMALT system variable
DIMALTD system variable
DIMALTF system variable
DIMALTRND system variable
DIMALTTD system variable
DIMALTTZ system variable
DIMALTU system variable
DIMALTZ system variable
DIMANNO system variable
DIMAPOST system variable
DIMARCSYM system variable
DIMASO system variable
DIMASSOC system variable
DIMASZ system variable
DIMATFIT system variable
DIMAUNIT system variable
DIMAZIN system variable
DIMBLK system variable
DIMBLK1 system variable
DIMBLK2 system variable
DIMCEN system variable
DIMCLRD system variable
DIMCLRE system variable
DIMCLRT system variable
DIMDEC system variable
DIMDLE system variable
DIMDLI system variable
DIMDSEP system variable
DIMEXE system variable
DIMEXO system variable
DIMFIT system variable
DIMFRAC system variable
DIMFXL system variable
DIMFXLON system variable
DIMGAP system variable
DIMJOGANG system variable
DIMJUST system variable
DIMLAYER system variable
DIMLDRBLK system variable
DIMLFAC system variable
DIMLIM system variable
DIMLTEX1 system variable
DIMLTEX2 system variable
DIMLTYPE system variable
DIMLUNIT system variable
DIMLWD system variable
DIMLWE system variable
DIMPOST system variable
DIMRND system variable
DIMSAH system variable
DIMSCALE system variable
DIMSD1 system variable
DIMSD2 system variable
DIMSE1 system variable
DIMSE2 system variable
DIMSHO system variable
DIMSOXD system variable
DIMSTYLE system variable
DIMTAD system variable
DIMTDEC system variable
DIMTFAC system variable
DIMTFILL system variable
DIMTFILLCLR system variable
DIMTIH system variable
DIMTIX system variable
DIMTM system variable
DIMTMOVE system variable
DIMTOFL system variable
DIMTOH system variable
DIMTOL system variable
DIMTOLJ system variable
DIMTP system variable
DIMTSZ system variable
DIMTVP system variable
DIMTXSTY system variable
DIMTXT system variable
DIMTXTDIRECTION system variable
DIMTZIN system variable
DIMUNIT system variable
DIMUPT system variable
DIMZIN system variable
DISPLAYAXES system variable
DISPLAYAXESFORMEP system variable
DISPLAYSCALING system variable
DISPLAYSIDESANDENDS system variable
DISPLAYSNAPMARKERINALLVIEWS system variable
DISPLAYTOOLTIPS system variable
DISPPAPERBKG system variable
DISPPAPERMARGINS system variable
DISPSILH system variable
DMAUDITLEVEL system variable
DMAUTOUPDATE system variable
DMCONNECTIONCUTTYPE system variable
DMPUSHPULLSUBTRACT system variable
DMRECOGNIZE system variable
DOCKPRIORITY system variable
DOCTABPOSITION system variable
DONUTID system variable
DONUTOD system variable
DRAGMODE system variable
DRAGMODEHIDE system variable
DRAGMODEINTERRUPT system variable
DRAGOPEN system variable
DRAGP1 system variable
DRAGP2 system variable
DRAGSNAP system variable
DRAWINGPATH system variable
DRAWINGVIEWPRESET system variable
DRAWINGVIEWPRESETHIDDEN system variable
DRAWINGVIEWPRESETSCALE system variable
DRAWINGVIEWPRESETTANGENT system variable
DRAWINGVIEWPRESETTRAILING system variable
DRAWINGVIEWQUALITY system variable
DRAWORDERCTL system variable
DWFFORMAT system variable
DWFFRAME system variable
DWFOSNAP system variable
DWFVERSION system variable
DWGCHECK system variable
DWGCODEPAGE system variable
DWGGUIDCLOUDAI system variable
DWGNAME system variable
DWGPREFIX system variable
DWGTITLED system variable
DXEVAL system variable
DXFTEXTADJUSTALIGNMENT system variable
DYNCONSTRAINTMODE system variable
DYNDIGRIP system variable
DYNDIMAPERTURE system variable
DYNDIMCOLORHOT system variable
DYNDIMCOLORHOVER system variable
DYNDIMDISTANCE system variable
DYNDIMLINETYPE system variable
DYNDIVIS system variable
DYNINPUTTRANSPARENCY system variable
DYNMODE system variable
DYNPICOORDS system variable
DRAWINGVIEWFLAGS system variable
E
EDGEMODE system variable
ELEVATION system variable
ELEVATIONATBREAKLINECROSSINGS system variable
ENABLEATTRACTION system variable
ENABLEBIMBKUPDATE system variable
ENABLEHYPERLINKMENU system variable
ENABLEHYPERLINKTOOLTIP system variable
ERRNO system variable
EXPERT system variable
EXPINSALIGN system variable
EXPINSANGLE system variable
EXPINSFIXANGLE system variable
EXPINSFIXSCALE system variable
EXPINSSCALE system variable
EXPLMODE system variable
EXPORT3DPDFWRITER system variable
EXPORTACISASSEMBLYWRITER system variable
EXPORTACISFORMATVERSION system variable
EXPORTCATIAV4FORMATVERSION system variable
EXPORTCATIAV5FORMATVERSION system variable
EXPORTGEOMETRYFLAGS system variable
EXPORTHIDDENPARTS system variable
EXPORTMODELSPACE system variable
EXPORTPAGESETUP system variable
EXPORTPAPERSPACE system variable
EXPORTPARASOLIDFORMATVERSION system variable
EXPORTPRODUCTSTRUCTURE system variable
EXPORTSTEPFORMATVERSION system variable
EXPORTXCGMFORMATVERSION system variable
EXTMAX system variable
EXTMIN system variable
EXTNAMES system variable
EXTRUDEINSIDE system variable
EXTRUDEOUTSIDE system variable
F
FACETRATIO system variable
FACETRES system variable
FBXEXPORTCAMERAS system variable
FBXEXPORTENTITIES system variable
FBXEXPORTENTITIESSELTYPE system variable
FBXEXPORTLIGHTS system variable
FBXEXPORTMATERIALS system variable
FBXEXPORTTEXTURES system variable
FBXEXPORTTEXTURESPATH system variable
FEATURECOLORS system variable
FIELDDISPLAY system variable
FIELDEVAL system variable
FILEDIA system variable
FILLETRAD system variable
FILLMODE system variable
FINALTREAD system variable
FINALTREADLENGTH system variable
FITARCMAXGAP system variable
FITLINEFITARCMODE system variable
FITTINGRADIUSTYPE system variable
FITTINGRADIUSVALUE system variable
FLOORTOFLOORDISTANCE system variable
FONTALT system variable
FONTMAP system variable
FRAMESELECTION system variable
FRONTZ system variable
FULLOPEN system variable
G
GEARTEETHNUMBER system variable
GENERATEASSOCATTRS system variable
GENERATEASSOCVIEWS system variable
GEOLATLONGFORMAT system variable
GEOMARKERVISIBILITY system variable
GEOMRELATIONS system variable
GETSTARTED system variable
GFANG system variable
GFCLR1 system variable
GFCLR2 system variable
GFCLRLUM system variable
GFCLRSTATE system variable
GFNAME system variable
GFSHIFT system variable
GLSWAPMODE system variable
GRADIENTCOLORBOTTOM system variable
GRADIENTCOLORMIDDLE system variable
GRADIENTCOLORTOP system variable
GRADIENTMODE system variable
GRIDAXISCOLOR system variable
GRIDDISPLAY system variable
GRIDMAJOR system variable
GRIDMAJORCOLOR system variable
GRIDMINORCOLOR system variable
GRIDMODE system variable
GRIDSTYLE system variable
GRIDUNIT system variable
GRIDXYZTINT system variable
GRIPBLOCK system variable
GRIPCOLOR system variable
GRIPDYNCOLOR system variable
GRIPHOT system variable
GRIPHOVER system variable
GRIPOBJLIMIT system variable
GRIPS system variable
GRIPSIZE system variable
GRIPTIPS system variable
GSDEVICETYPE2D system variable
GSDEVICETYPE3D system variable
H
HALOGAP system variable
HANDLES system variable
HEADROOM system variable
HANDSEED system variable
HIDEPRECISION system variable
HIDESYSTEMPRINTERS system variable
HIDETEXT system variable
HIDEXREFSCALES system variable
HIGHLIGHT system variable
HIGHLIGHTCOLOR system variable
HIGHLIGHTEFFECT system variable
HORIZONBKG_ENABLE system variable
HORIZONBKG_GROUNDHORIZON system variable
HORIZONBKG_GROUNDORIGIN system variable
HORIZONBKG_SKYHIGH system variable
HORIZONBKG_SKYHORIZON system variable
HORIZONBKG_SKYLOW system variable
HOTKEYASSISTANT system variable
HPANG system variable
HPANNOTATIVE system variable
HPASSOC system variable
HPBACKGROUNDCOLOR system variable
HPBOUND system variable
HPBOUNDRETAIN system variable
HPCOLOR system variable
HPDOUBLE system variable
HPDRAWORDER system variable
HPGAPTOL system variable
HPISLANDDETECTION system variable
HPLAYER system variable
HPLINETYPE system variable
HPMAXAREAS system variable
HPNAME system variable
HPOBJWARNING system variable
HPORIGIN system variable
HPSCALE system variable
HPSEPARATE system variable
HPSPACE system variable
HPTRANSPARENCY system variable
HYPERLINKBASE system variable
I
IFCCREATEUNIQUEGUID system variable
IFCEXPLODEEXTERNALREFERENCES system variable
IFCEXPORTBASEQUANTITIES system variable
IFCEXPORTELEMENTSONOFFANDFROZENLAYER system variable
IFCEXPORTMAPPINGPATH system variable
IFCEXPORTMULTIPLYELEMENTSASAGGREGATED system variable
IFCEXPORTPROFILECENTEROFGRAVITY system variable
IFCEXPORTSWEPTSOLIDSASBREP system variable
IFCEXPORTTESSELATION system variable
IFCIMPORTBIMDATA system variable
IFCIMPORTBREPGEOMETRYASMESHES system variable
IFCIMPORTMAPPINGPATH system variable
IFCIMPORTMODELORIGIN system variable
IFCIMPORTPARAMETRICCOMPONENTS system variable
IFCIMPORTPROJECTSTRUCTUREASXREFS system variable
IFCIMPORTSPACES system variable
IFCIMPORTUSESUBDMESH system variable
IFCTESSELATEBSPLINECURVESANDSURFACES system variable
IMAGECACHEFOLDER system variable
IMAGECACHEMAXMEMORY system variable
IMAGEDISKCACHE system variable
IMAGEFRAME system variable
IMAGEHLT system variable
IMAGENOTIFY system variable
IMPORTACISWITHBRICSCAD system variable
IMPORTCATIAV5REPRESENTATION system variable
IMPORTCATIAV5EDGEATTRIBUTES system variable
IMPORTCATIAV5SEARCHPATHSPREFERENCE system variable
IMPORTCREOALTERNATESEARCHPATHS system variable
IMPORTIGESSTITCH system variable
IMPORTINVENTORSEARCHPATHSPREFERENCE system variable
IMPORTNXSEARCHPATHSPREFERENCE system variable
IMPORTJTREPRESENTATION system variable
IMPORTCOLORS system variable
IMPORTCUIFILEEXISTS system variable
IMPORTHIDDENPARTS system variable
IMPORTIGESSIMPLIFY system variable
IMPORTINVENTORALTERNATESEARCHPATHS system variable
IMPORTNXALTERNATESEARCHPATHS system variable
IMPORTPMI system variable
IMPORTPRODUCTSTRUCTURE system variable
IMPORTREPAIR system variable
IMPORTSIMPLIFY system variable
IMPORTSOLIDEDGEALTERNATESEARCHPATHS system variable
IMPORTSOLIDEDGESEARCHPATHSPREFERENCE system variable
IMPORTSOLIDWORKSALTERNATESEARCHPATHS system variable
IMPORTSOLIDWORKSREPRESENTATION system variable
IMPORTSOLIDWORKSROTATEYZ system variable
IMPORTSOLIDWORKSSEARCHPATHSPREFERENCE system variable
IMPORTSTEPROTATEYZ system variable
IMPORTSTITCH system variable
INCLUDEPLOTSTAMP system variable
INDEXCTL system variable
INETLOCATION system variable
INSBASE system variable
INSNAME system variable
INSUNITS system variable
INSUNITSDEFSOURCE system variable
INSUNITSDEFTARGET system variable
INSUNITSSCALING system variable
INTERFERECOLOR system variable
INTERFERELAYER system variable
INTERFERENCELEVEL system variable
INTERFEREOBJVS system variable
INTERFEREVPVS system variable
INTERIORELEVATIONMINLENGTH system variable
INTERIORELEVATIONOFFSET system variable
INTERSECTEDENTITIES system variable
INTERSECTIONCOLOR system variable
INTERSECTIONDISPLAY system variable
ISAVEBAK system variable
ISAVEPERCENT system variable
ISOLINES system variable
IFCMATCHIMPORTEDPROFILESGEOMETRICALLY system variable
J
K
L
LANDINGEXTENSIONDOWN system variable
LANDINGEXTENSIONUP system variable
LASTANGLE system variable
LASTPOINT system variable
LASTPROMPT system variable
LATITUDE system variable
LAYERFILTEREXCESS system variable
LAYERPMODE system variable
LAYLOCKFADECTL system variable
LAYOUTREGENCTL system variable
LAYOUTTAB system variable
LEGACYCODESEARCH system variable
LENGTHSAMPLINGINTERVAL system variable
LENGTHUNITS system variable
LENSLENGTH system variable
LICFLAGS system variable
LIGHTGLYPHCOLOR system variable
LIGHTGLYPHDISPLAY system variable
LIGHTINGUNITS system variable
LIGHTWEBGLYPHCOLOR system variable
LIMCHECK system variable
LIMMAX system variable
LIMMIN system variable
LINEARBRIGHTNESS system variable
LINEARCONTRAST system variable
LISPINIT system variable
LOADMECHANICAL2D system variable
LOCALE system variable
LOCALROOTPREFIX system variable
LOCKUI system variable
LOFTANG1 system variable
LOFTANG2 system variable
LOFTMAG1 system variable
LOFTMAG2 system variable
LOFTNORMALS system variable
LOFTPARAM system variable
LOGFILEMODE system variable
LOGFILENAME system variable
LOGFILEPATH system variable
LOGGEDIN system variable
LOGINNAME system variable
LONGITUDE system variable
LOOKFROMDIRECTIONMODE system variable
LOOKFROMFEEDBACK system variable
LOOKFROMZOOMEXTENTS system variable
LTGAPSELECTION system variable
LUNITS system variable
LUPREC system variable
LWDEFAULT system variable
LWDISPLAY system variable
LWDISPSCALE system variable
LWUNITS system variable
M
MACROREC system variable
MAKEBAK system variable
MANIPULATOR system variable
MANIPULATORCOLORTHEME system variable
MANIPULATORDURATION system variable
MANIPULATORHANDLE system variable
MANIPULATORSIZE system variable
MASSPREC system variable
MASSPROPACCURACY system variable
MASSUNITS system variable
MAXACTVP system variable
MAXHATCH system variable
MAXSORT system variable
MAXTHREADS system variable
MBSTATE system variable
MBUTTONPAN system variable
MEASUREINIT system variable
MEASUREMENT system variable
MECH2DSAVEFORMAT system variable
MECHANICALBLOCKS system variable
MECHANICALBROWSERSETTINGS system variable
MENUBAR (EXCEPT OS X) system variable
MENUCTL system variable
MENUECHO system variable
MENUNAME system variable
MESHTYPE system variable
MIDDLECLICKCLOSE system variable
MILLISECS system variable
MIRRTEXT system variable
MLEADERSCALE system variable
MODEMACRO system variable
MSLTSCALE system variable
MSOLESCALE system variable
MTEXTCOLUMN system variable
MTEXTDETECTSPACE system variable
MTEXTED system variable
MTEXTFIXED system variable
MTEXTTOOLBAR system variable
MTFLAGS system variable
MULTISELECTANGULARTOLERANCE system variable
MYDOCUMENTSPREFIX system variable
N
NAVVCUBEDISPLAY system variable
NAVVCUBELOCATION system variable
NAVVCUBEOPACITY system variable
NAVVCUBEORIENT system variable
NEARESTDISTANCE system variable
NOMUTT system variable
NORTHDIRECTION system variable
NOSING system variable
O
OBJECTISOLATIONMODE system variable
OBSCUREDCOLOR system variable
OBSCUREDLTYPE system variable
OFFSETDIST system variable
OFFSETERASE system variable
OFFSETGAPTYPE system variable
OLEFRAME system variable
OLEHIDE system variable
OLEQUALITY system variable
OLESTARTUP system variable
OPMSTATE system variable
ORBITAUTOTARGET system variable
ORTHOMODE system variable
OSNAPCOORD system variable
OSNAPZ system variable
OSOPTIONS system variable
OVERKILLLAYER system variable
P
PANBUFFER system variable
PANELBUTTONSIZE system variable
PAPERUPDATE system variable
PARAMETERCOPYMODE system variable
PARAMETRICBLOCKS2DPATH system variable
PDFCACHE system variable
PDFEMBEDDEDTTF system variable
PDFEXPORTHYPERLINKS system variable
PDFFRAME system variable
PDFIMAGEANTIALIAS system variable
PDFIMAGECOMPRESSION system variable
PDFIMAGEDPI system variable
PDFIMPORTAPPLYLINEWEIGHT system variable
PDFIMPORTASBLOCK system variable
PDFIMPORTCHARSPACEFACTOR system variable
PDFIMPORTCOMBINETEXTOBJECTS system variable
PDFIMPORTCONVERTSOLIDSTOHATCHES system variable
PDFIMPORTIMAGEPATH system variable
PDFIMPORTJOINLINEANDARCSEGMENTS system variable
PDFIMPORTLAYERSUSETYPE system variable
PDFIMPORTRASTERIMAGES system variable
PDFIMPORTSOLIDFILLS system variable
PDFIMPORTSPACEFACTOR system variable
PDFIMPORTTRUETYPETEXT system variable
PDFIMPORTTRUETYPETEXTASGEOMETRY system variable
PDFIMPORTUSECLIPPING system variable
PDFIMPORTUSEGEOMETRYOPTIMIZATION system variable
PDFIMPORTUSEIMAGECLIPPING system variable
PDFIMPORTUSEPAGEBORDERCLIPPING system variable
PDFIMPORTVECTORGEOMETRY system variable
PDFLAYERSSETTING system variable
PDFLAYOUTSTOEXPORT system variable
PDFMERGECONTROL system variable
PDFNOTIFY system variable
PDFOSNAP system variable
PDFPAPERHEIGHT system variable
PDFPAPERSIZEOVERRIDE system variable
PDFPAPERWIDTH system variable
PDFPRCCOMPRESSION system variable
PDFPRCEXPORT system variable
PDFPRCPROJECTION system variable
PDFPRCVIEWMODE system variable
PDFSHXTEXTASGEOMETRY system variable
PDFSIMPLEGEOMOPTIMIZATION system variable
PDFTTFTEXTASGEOMETRY system variable
PDFUSEPLOTSTYLES system variable
PDFVECTORRESOLUTIONDPI system variable
PDFZOOMTOEXTENTSMODE system variable
PDMODE system variable
PDSIZE system variable
PEDITACCEPT system variable
PELLIPSE system variable
PERIMETER system variable
PERSPECTIVE system variable
PFACEVMAX system variable
PICKADD system variable
PICKAUTO system variable
PICKBOX system variable
PICKDRAG system variable
PICKFIRST system variable
PICKSTYLE (EXCEPT OS X) system variable
PICTUREEXPORTSCALE system variable
PLACESBARFOLDER1 system variable
PLACESBARFOLDER2 system variable
PLACESBARFOLDER3 system variable
PLACESBARFOLDER4 system variable
PLATFORM system variable
PLINECACHE system variable
PLINECONVERTMODE system variable
PLINEGEN system variable
PLINEWID system variable
PLOTCFGPATH system variable
PLOTID system variable
PLOTOUTPUTPATH system variable
PLOTSTYLEPATH system variable
PLOTTER system variable
PLOTTRANSPARENCYOVERRIDE system variable
PLQUIET system variable
POINTCLOUD2DVSDISPLAY system variable
POINTCLOUDADAPTIVEDISPLAY system variable
POINTCLOUDBOUNDARY system variable
POINTCLOUDCACHEFOLDER system variable
POINTCLOUDCACHESIZE system variable
POINTCLOUDPOINTMAX system variable
POINTCLOUDPOINTSIZE system variable
POLARADDANG system variable
POLARANG system variable
POLARDIST system variable
POLARMODE system variable
POLYSIDES system variable
POPUPS system variable
PREVIEWDELAY system variable
PREVIEWEFFECT system variable
PREVIEWFILTER system variable
PREVIEWTYPE system variable
PREVIEWWNDINOPENDLG system variable
PRINTFILE system variable
PRINTPDFPREVIEW system variable
PRODUCT system variable
PROFILEOFFSETBEHAVIOR system variable
PROGBAR system variable
PROGRAM system variable
PROJECTIONTYPE system variable
PROJECTNAME system variable
PROJECTSEARCHPATHS system variable
PROJMODE system variable
PROMPTMENU system variable
PROMPTMENUFLAGS system variable
PROMPTOPTIONFORMAT system variable
PROMPTOPTIONTRANSLATEKEYWORDS system variable
PROPAGATESEARCHSPACE system variable
PROPAGATETOLERANCE system variable
PROPERTYPREVIEW system variable
PROPERTYPREVIEWDELAY system variable
PROPERTYPREVIEWOBJLIMIT system variable
PROPPREVTIMEOUT system variable
PROPUNITS system variable
PROXYGRAPHICS system variable
PROXYNOTICE system variable
PROXYSHOW system variable
PROXYWEBSEARCH system variable
PSLTSCALE system variable
PSOLHEIGHT system variable
PSOLWIDTH system variable
PSTYLEMODE system variable
PSTYLEPOLICY system variable
PSVPSCALE system variable
PUBLISHALLSHEETS system variable
PUBLISHCOLLATE system variable
PUCSBASE system variable
PDFANIMATIONFPS system variable
Q
QAFLAGS system variable
QTEXTMODE system variable
QUADCOMMANDLAUNCH system variable
QUADDISPLAY system variable
QUADEXPANDDELAY system variable
QUADEXPANDTABDELAY system variable
QUADGOTRANSPARENT system variable
QUADHIDEDELAY system variable
QUADHIDEMARGIN system variable
QUADICONSIZE system variable
QUADICONSPACE system variable
QUADMOSTRECENTITEMS system variable
QUADPOPUPCORNER system variable
QUADROLLOVERDELAY system variable
QUADSHOWDELAY system variable
QUADWIDTH system variable
R
R12SAVEACCURACY system variable
R12SAVEDEVIATION system variable
RASTERPREVIEW system variable
RE_INIT system variable
REALTIMESPEEDUP system variable
REALWORLDSCALE system variable
RECENTFILES system variable
RECENTPATH system variable
REDHILITE_DUCSLOCKED_FACE_ALPHA system variable
REDHILITE_DUCSLOCKED_FACE_COLOR system variable
REDHILITE_HIDDENEDGE_ALPHA system variable
REDHILITE_HIDDENEDGE_COLOR system variable
REDHILITEFULL_EDGE_ALPHA system variable
REDHILITEFULL_EDGE_COLOR system variable
REDHILITEFULL_EDGE_SHOWHIDDEN system variable
REDHILITEFULL_EDGE_SMOOTHING system variable
REDHILITEFULL_EDGE_THICKNESS system variable
REDHILITEFULL_FACE_ALPHA system variable
REDHILITEFULL_FACE_COLOR system variable
REDHILITEPARTIAL_SELECTEDEDGE_ALPHA system variable
REDHILITEPARTIAL_SELECTEDEDGE_COLOR system variable
REDHILITEPARTIAL_SELECTEDEDGE_SHOWGLOW system variable
REDHILITEPARTIAL_SELECTEDEDGE_SMOOTHING system variable
REDHILITEPARTIAL_SELECTEDEDGE_THICKNESS system variable
REDHILITEPARTIAL_SELECTEDEDGEGLOW_ALPHA system variable
REDHILITEPARTIAL_SELECTEDEDGEGLOW_COLOR system variable
REDHILITEPARTIAL_SELECTEDEDGEGLOW_SMOOTHING system variable
REDHILITEPARTIAL_SELECTEDEDGEGLOW_THICKNESS system variable
REDHILITEPARTIAL_SELECTEDFACE_ALPHA system variable
REDHILITEPARTIAL_SELECTEDFACE_COLOR system variable
REDHILITEPARTIAL_UNSELECTEDEDGE_SHOWHIDDEN system variable
REDSDKLINESMOOTHING system variable
REDUCELENGTHTYPE system variable
REDUCELENGTHVALUE system variable
REFEDITLOCKNOTINWORKSET system variable
REFEDITNAME system variable
REFPATHTYPE system variable
REGENMODE system variable
REGEXPAND system variable
REMEMBERFOLDERS system variable
RENDERCOMPOSITIONMATERIAL system variable
RENDERMATERIALDOWNLOAD system variable
RENDERMATERIALSPATH system variable
RENDERUSINGHARDWARE system variable
REPORTPANELMODE system variable
REPOSITORYFOLDER system variable
RESTORECONNECTIONS system variable
RESTORELOSTFOCUS system variable
REVCLOUDARCSTYLE system variable
REVCLOUDCREATEMODE system variable
REVCLOUDGRIPS system variable
REVCLOUDMAXARCLENGTH system variable
REVCLOUDMINARCLENGTH system variable
RHINOVERSION system variable
RIBBONDOCKEDHEIGHT system variable
RIBBONPANELMARGIN system variable
RIBBONSTATE system variable
RIBBONTOOLSIZE system variable
RISERHEIGHT system variable
ROAMABLEROOTPREFIX system variable
ROLLOVEROPACITY system variable
ROLLOVERSELECTIONSET system variable
ROLLOVERTIPS system variable
RTDISPLAY system variable
RTROTATIONSPEEDFACTOR系统变量
RUBBERBANDCOLOR system variable
RUBBERBANDSTYLE system variable
RUBBERSHEET (for OS X) system variable
RUBBERSHEETSENSIBILITY (FOR OS X) system variable
RUNASLEVEL system variable
RVTLEVELOFDETAIL system variable
RVTVALIDATEBREP system variable
S
SAFEMODE system variable
SAVECHANGETOLAYOUT system variable
SAVEFIDELITY system variable
SAVEFILE system variable
SAVEFILEPATH system variable
SAVELAYERSNAPSHOT system variable
SAVENAME system variable
SAVEONDOCSWITCH system variable
SAVEROUNDTRIP system variable
SAVETIME system variable
SCREENBOXES system variable
SCREENMODE system variable
SCREENSIZE system variable
SCRLHIST system variable
SDI system variable
SECTIONRESULTINTERVAL system variable
SECTIONSCALE system variable
SECTIONSETTINGSSEARCHPATH system variable
SECTIONSHEETSETTEMPLATEIMPERIAL system variable
SECTIONSHEETSETTEMPLATEMETRIC system variable
SECURELOAD system variable
SELECTIONANNODISPLAY system variable
SELECTIONAREA system variable
SELECTIONAREAOPACITY system variable
SELECTIONMODES system variable
SELECTIONPREVIEW system variable
SELECTSIMILARMODE system variable
SETBYLAYERMODE system variable
SHADEDGE system variable
SHADEDIF system variable
SHEETNUMBERLEADINGZEROES system variable
SHEETSETAUTOBACKUP system variable
SHEETSETTEMPLATEPATH system variable
SHORTCUTMENU system variable
SHORTCUTMENUDURATION system variable
SHOWDOCTABS system variable
SHOWFULLPATHINTITLE system variable
SHOWLAYERUSAGE system variable
SHOWSCROLLBUTTONS system variable
SHOWTABCLOSEBUTTON system variable
SHOWTABCLOSEBUTTONACTIVE system variable
SHOWTABCLOSEBUTTONALL system variable
SHOWWINDOWLISTBUTTON system variable
SHPNAME system variable
SIGWARN system variable
SINGLETONMODE system variable
SKETCHINC system variable
SKPOLY system variable
SKYSTATUS system variable
SLABTHICKNESS system variable
SMASSEMBLYEXPORTMODE system variable
SMASSEMBLYEXPORTREPORTPATHTYPE system variable
SMASSEMBLYEXPORTSOLIDTYPESINREPORTS system variable
SMATTRIBUTESLAYERCOLOR system variable
SMATTRIBUTESLAYERTEXTHEIGHT system variable
SMATTRIBUTESLAYERTEXTHEIGHTTYPE system variable
SMBENDANNOTATIONSLAYERCOLOR system variable
SMBENDANNOTATIONSLAYERTEXTHEIGHT system variable
SMBENDANNOTATIONSLAYERTEXTHEIGHTTYPE system variable
SMBENDLINESDOWNLAYERCOLOR system variable
SMBENDLINESDOWNLAYERLINETYPE system variable
SMBENDLINESDOWNLAYERLINEWEIGHT system variable
SMBENDLINESUPLAYERCOLOR system variable
SMBENDLINESUPLAYERLINETYPE system variable
SMBENDLINESUPLAYERLINEWEIGHT system variable
SMBEVELFEATURECOLOR system variable
SMCOLORBEND system variable
SMCOLORBENDRELIEF system variable
SMCOLORBEVEL system variable
SMCOLORCORNERRELIEF system variable
SMCOLORFLANGE system variable
SMCOLORFLANGEREFERENCESIDE system variable
SMCOLORFORM system variable
SMCOLORHEM system variable
SMCOLORJOG system variable
SMCOLORJUNCTION system variable
SMCOLORLOFTEDBEND system variable
SMCOLORMITER system variable
SMCOLORROLLEDEDGE system variable
SMCOLORTAB system variable
SMCOLORWRONGBEND system variable
SMCOLORWRONGFLANGE system variable
SMCONTOURSLAYERCOLOR system variable
SMCONTOURSLAYERLINETYPE system variable
SMCONTOURSLAYERLINEWEIGHT system variable
SMCONVERTMAXIMALBEVELANGLE system variable
SMCONVERTMINIMALBEVELANGLE system variable
SMCONVERTPREFERFORMFEATURES system variable
SMCONVERTPREFERHEMFEATURES system variable
SMCONVERTPREFERZEROBENDFEATURES system variable
SMCONVERTRECOGNIZEHOLES system variable
SMCONVERTRECOGNIZERIBCONTROLCURVES system variable
SMCONVERTWRONGFEATURETHICKNESSDEVIATIONTYPE system variable
SMCONVERTWRONGFEATURETHICKNESSDEVIATIONVALUE system variable
SMDEFAULTBENDLINEEXTENTTYPE system variable
SMDEFAULTBENDLINEEXTENTVALUE system variable
SMDEFAULTBENDRADIUSTYPE system variable
SMDEFAULTBENDRADIUSVALUE system variable
SMDEFAULTBENDRELIEFWIDTHTYPE system variable
SMDEFAULTBENDRELIEFWIDTHVALUE system variable
SMDEFAULTBEVELFEATUREUNFOLDMODE system variable
SMDEFAULTCORNERRELIEFDIAMETERVALUE system variable
SMDEFAULTFLANGESPLITEXTENSIONTYPE system variable
SMDEFAULTFLANGESPLITEXTENSIONVALUE system variable
SMDEFAULTFLANGESPLITGAPTYPE system variable
SMDEFAULTFLANGESPLITGAPVALUE system variable
SMDEFAULTFORMFEATUREUNFOLDMODE system variable
SMDEFAULTHEMGAPTYPE system variable
SMDEFAULTHEMGAPVALUE system variable
SMDEFAULTHEMRELATIVEBENDDEDUCTION system variable
SMDEFAULTJUNCTIONALIGNMENTTORELIEF system variable
SMDEFAULTJUNCTIONGAPTYPE system variable
SMDEFAULTJUNCTIONGAPVALUE system variable
SMDEFAULTKFACTOR system variable
SMDEFAULTLOFTEDBENDNUMBERSAMPLES system variable
SMDEFAULTRELIEFEXTENSIONTYPE system variable
SMDEFAULTRELIEFEXTENSIONVALUE system variable
SMDEFAULTRIBFILLETRADIUSTYPE system variable
SMDEFAULTRIBFILLETRADIUSVALUE system variable
SMDEFAULTRIBPROFILERADIUSTYPE system variable
SMDEFAULTRIBPROFILERADIUSVALUE system variable
SMDEFAULTRIBROUNDRADIUSTYPE system variable
SMDEFAULTRIBROUNDRADIUSVALUE system variable
SMDEFAULTSHARPBENDRADIUSLIMITRATIO system variable
SMDEFAULTTABCHAMFERDISTANCETYPE system variable
SMDEFAULTTABCHAMFERDISTANCEVALUE system variable
SMDEFAULTTABCLEARANCETYPE system variable
SMDEFAULTTABCLEARANCEVALUE system variable
SMDEFAULTTABDISTANCETYPE system variable
SMDEFAULTTABDISTANCEVALUE system variable
SMDEFAULTTABEDGETYPE system variable
SMDEFAULTTABFILLETRADIUSTYPE system variable
SMDEFAULTTABFILLETRADIUSVALUE system variable
SMDEFAULTTABHEIGHTTYPE system variable
SMDEFAULTTABHEIGHTVALUE system variable
SMDEFAULTTABLENGTHTYPE system variable
SMDEFAULTTABLENGTHVALUE system variable
SMDEFAULTTABSLOTNUMBER system variable
SMDEFAULTTHICKNESS system variable
SMEXPORTOSMAPPROXIMATIONACCURACY system variable
SMEXPORTOSMMINIMALEDGELENGTH system variable
SMFORMFEATURESDOWNCOLOR system variable
SMFORMFEATURESDOWNLAYERLINETYPE system variable
SMFORMFEATURESDOWNLAYERLINEWEIGHT system variable
SMFORMFEATURESUPCOLOR system variable
SMFORMFEATURESUPLAYERLINETYPE system variable
SMFORMFEATURESUPLAYERLINEWEIGHT system variable
SMJUNCTIONCREATEHEALCOINCIDENT system variable
SMOOTHMESHCONVERT system variable
SMOVERALLANNOTATIONSLAYERCOLOR system variable
SMOVERALLANNOTATIONSLAYERLINETYPE system variable
SMOVERALLANNOTATIONSLAYERLINEWEIGHT system variable
SMPARAMETRIZEHOLESPARAMETRIZATION system variable
SMREPAIRLOFTEDBENDMERGE system variable
SMSMARTFEATURES system variable
SMSPLITAMBIGUOUSINPUT system variable
SMSPLITCONVERTBENDTOJUNCTION system variable
SMSPLITHEALCOINCIDENT system variable
SMSPLITORTHOGONALBENDSPLIT system variable
SMTARGETCAM system variable
SNAPANG system variable
SNAPBASE system variable
SNAPCOLOR system variable
SNAPISOPAIR system variable
SNAPMARKERSIZE system variable
SNAPMARKERTHICKNESS system variable
SNAPMODE system variable
SNAPSIZE system variable
SNAPSTYL system variable
SNAPTHICKNESS system variable
SNAPTYPE system variable
SNAPUNIT system variable
SOLIDCHECK system variable
SORTENTS system variable
SPAADJUSTMODE system variable
SPACHECKLEVEL system variable
SPAGRIDASPECTRATIO system variable
SPAGRIDMODE system variable
SPAMAXFACETEDGELENGTH system variable
SPAMAXNUMGRIDLINES system variable
SPAMINUGRIDLINES system variable
SPAMINVGRIDLINES system variable
SPANORMALTOL system variable
SPASURFACETOL system variable
SPATRIANGMODE system variable
SPAUSEFACETRES system variable
SPLFRAME system variable
SPLINESEGS system variable
SPLINETYPE system variable
SRCHPATH system variable
SSFOUND system variable
SSLOCATE system variable
SSMAUTOOPEN system variable
SSMPOLLTIME system variable
SSMSHEETSTATUS system variable
SSMSTATE system variable
STACKPANELTYPE system variable
STAIRWIDTH system variable
STAMPFONTSIZE system variable
STAMPFONTSTYLE system variable
STAMPFOOTER system variable
STAMPFOOTEROFFSETX system variable
STAMPFOOTEROFFSETY system variable
STAMPHEADER system variable
STAMPHEADEROFFSETX system variable
STAMPHEADEROFFSETY system variable
STAMPUNITS system variable
STANDARDSOPTIONS system variable
STANDARDSVIOLATION system variable
STARTUPTODAY system variable
STATUSBAR system variable
STEPSIZE系统变量
STEPSPERSEC系统变量
STEPTHICKNESS system variable
STLPOSITIVEQUADRANT system variable
STRUCTURETREECONFIG system variable
SURFTAB1 system variable
SURFTAB2 system variable
SURFTYPE system variable
SURFU system variable
SURFV system variable
SVGBLENDEDGRADIENTS system variable
SVGDEFAULTIMAGEEXTENSION system variable
SVGGENERICFONTFAMILY system variable
SVGIMAGEBASE system variable
SVGIMAGEURL system variable
SVGLINEWEIGHTSCALE system variable
SVGOUTPUTHEIGHT system variable
SVGOUTPUTWIDTH system variable
SVGPRECISION system variable
SVGSCALEFACTOR system variable
SYSCODEPAGE system variable
T
TABCONTROLHEIGHT system variable
TABMODE system variable
TABSFIXEDWIDTH system variable
TANGENTLENGTHTYPE system variable
TANGENTLENGTHVALUE system variable
TDCREATE system variable
TDINDWG system variable
TDUCREATE system variable
TDUPDATE system variable
TDUSRTIMER system variable
TDUUPDATE system variable
TEETANGENTLENGTHTYPE system variable
TEETANGENTLENGTHVALUE system variable
TEMPPREFIX system variable
TEXTANGLE system variable
TEXTEDITMODE system variable
TEXTEVAL system variable
TEXTFILL system variable
TEXTQLTY system variable
TEXTSIZE system variable
TEXTSTYLE system variable
TEXTUREMAPPATH system variable
THREADDISPLAY system variable
THUMBSIZE system variable
TILEMODE system variable
TILEMODELIGHTSYNCH system variable
TIMEZONE system variable
TOOLBARMARGIN system variable
TOOLBUTTONSIZE system variable
TOOLICONPADDING system variable
TOOLPALETTEPATH system variable
TOOLTIPDELAY system variable
TPSTATE system variable
TRACEWID system variable
TRACKPATH system variable
TRANSPARENCYDISPLAY system variable
TRAYICONS system variable
TRAYNOTIFY system variable
TRAYTIMEOUT system variable
TREEDEPTH system variable
TREEMAX system variable
TRIMMODE system variable
TRUSTEDPATHS system variable
TSPACEFAC system variable
TSPACETYPE system variable
TSTACKALIGN system variable
TSTACKSIZE system variable
TTFASTEXT system variable
U
UCSAXISANG system variable
UCSDETECT system variable
UCSFOLLOW system variable
UCSICON system variable
UCSICONPOS system variable
UCSNAME system variable
UCSORG system variable
UCSORTHO system variable
UCSVIEW system variable
UCSVP system variable
UCSXDIR system variable
UCSYDIR system variable
UNDOCTL system variable
UNDOMARKS system variable
UNITESURFACES system variable
UNITMODE system variable
USECOMMUNICATOR system variable
USERI1 system variable
USERI2 system variable
USERI3 system variable
USERI4 system variable
USERI5 system variable
USERR1 system variable
USERR2 system variable
USERR3 system variable
USERR4 system variable
USERR5 system variable
USERS1 system variable
USERS2 system variable
USERS3 system variable
USERS4 system variable
USERS5 system variable
USESTANDARDOPENFILEDIALOG system variable
V
VBAMACROS system variable
VENDORNAME system variable
VERBOSEBIMSECTIONUPDATE system variable
VERSIONCONTROLCONFIGPATH system variable
VERSIONCONTROLDOWNLOADPATH system variable
VERSIONCUSTOMIZABLEFILES system variable
VIEWCTR system variable
VIEWDIR system variable
VIEWSIZE system variable
VIEWTWIST system variable
VIEWUPDATEAUTO system variable
VISRETAIN system variable
VOLUMEPREC system variable
VOLUMEUNITS system variable
VPMAXIMIZEDSTATE system variable
VPROTATEASSOC system variable
VSMAX system variable
VSMIN system variable
VTDURATION system variable
VTENABLE system variable
VTFPS system variable
W
WALLWIDTH system variable
WARNINGMESSAGES system variable
WHIPARC system variable
WHIPTHREAD system variable
WINDOWAREACOLOR system variable
WIPEOUTFRAME system variable
WMFBKGND system variable
WMFFOREGND system variable
WNDLMAIN system variable
WNDLSCRL system variable
WNDLTEXT system variable
WNDPMAIN system variable
WNDPTEXT system variable
WNDSMAIN system variable
WNDSTEXT system variable
WORLDUCS system variable
WORLDVIEW system variable
WRITESTAT system variable
WSAUTOSAVE system variable
WSCURRENT system variable
X
XCLIPFRAME system variable
XDWGFADECTL system variable
XEDIT system variable
XFADECTL system variable
XLOADCTL system variable
XLOADPATH system variable
XNOTIFYTIME system variable
XREFCTL system variable
XREFNOTIFY system variable
XREFOVERRIDE system variable
Y
Z
ZOOMFACTOR system variable
ZOOMWHEEL system variable
Generated Drawings
Drawing Views
Drawing Annotations
Parent topic:
BricsCAD Mechanical
