Sheet Metal Settings
Overview
The Sheet Metal section in the Settings dialog box controls the different properties of Sheet Metal in BricsCAD. Properties are split into 4 groups: Commands, Feature colors, Initial parameters, and Modeling.
Commands
The Commands section contains settings that control the behavior of the various Sheet Metal commands.
The Layers used for Sheet Metal Unfolding determine the appearance of unfolded parts.
Feature colors
The Feature colors settings visually distinguish different types of sheet metal features by color. You can adjust the colors for each feature type.
Initial parameters
These parameters are responsible for the initialization of the Sheet Metal Context associated with a drawing.
Modeling
Modeling settings control the behavior of sheet metal features. Settings are grouped by feature type.
Unfolding
Unfolding settings control the behavior of K-factor value, Form feature unfolding mode, and Bend line extent type/value.
Modeling
The Modeling settings include the SMSMARTFEATURES user preference that controls the local, intelligent update of the geometry after Sheet Metal commands are executed.
