BIM BCF panel
The BIM BCF panel allows you to link information such as a comment, a screenshot, a list of involved objects and a camera viewport to an issue.
Menu
Opens the main menu of BIM BCF panel.
- Import BCF file
- Allows to import BIM Collaboration Format Files (*.bcf,*.bcfzip).
- Log in with custom service
- Allows you to connect to a cloud service to start collaborating on issues in the drawings.
- Refresh
- Makes sure you see the latest updates in case you are working on the cloud.
- Clear sources
- Disconnects you with the cloud service, in case you are online, or closes the .bcf file, in case you are working on an imported .bcf file.
Connect with a service
Opens the Custom log in dialog box.
Import a BCF file
Displays the Select a BIM Collaboration Format file to import dialog box.
