Details panel
The Details panel allows you to view details, add tags to details, propagate and adjust details.
Menu
- Grid View
- Displays the details in a grid view.
- List View
- Displays the details in a list view.
- Generate thumbnails
- Loads the new details in your library panel.
- Manage libraries
- Opens the Settings dialog box to change the details directory path.
Details library
You can click on the category of the detail you want to view. The details assigned to that category will be displayed.
When you click on a detail, the below dialog box will appear.
Create detail
Opens the Create detail dialog box.
