The Details panel allows you to view details, add tags to details, propagate and adjust details.
Home
Details library
Filter
Menu
List view / Grid view
Create detail
Home
Click this button to go back to the details library overview.
Details library
You can click on the category of the detail you want to view. The details assigned to
that category will be displayed.
When you click on a detail, the below dialog box will appear.
Parametrize
Open
Edit detail
Tolerance parameters
Tags
Reference solid tags
General tags
Save
Propagate
Filter
Click the filter icon to open the filter options. Here you can search the library for
specific details using tags.
Filters the details based on Reference solid tags. Click + Reference solid to add a filter and then select a filter from the drop-down list. You can copy or delete filters by clicking on the symbols on the right.
General tags
Filters the details based on General tags. Click on (click here to filter) to add filters. Select a tag from the drop-down list. Click the cross next to a filter to delete a filter, or click the delete icon to the left to delete all the added filters at once.
Menu
Generate thumbnails
Loads the new details in your library panel.
Manage libraries
Opens the Settings dialog box to change the details directory path.
Toggle between the list view and the grid view of the details by clicking the
icons.
Create detail
Opens the Create detail dialog box where you can select the reference solids, detail entities and section to create a new detail.
