Tool palettes panel
The Tool palettes panel offers a central location to access blocks, hatches, and command tools.
It includes default tabs with sample tools. You can easily create and customize your own tabs and tools using the right-click menu.
Right-click menus offer additional tools:
- Update tool image:
- Updates tool image for hatches and blocks.
- Specify Image…:
Allows you to specify another image for the tool.
Note: To restore the original tool image, right-click the tool and choose Remove Image in the context menu.
- Properties…:
- Opens the Tool Properties dialog box, which allows you to edit a tool.
- View Options…:
- Opens the View options dialog box, which allows you to edit the display of the tool icons.
- Add Text:
- Adds a text separator.
- Add Separator:
- Adds a line separator.
- Customize Palettes…:
- Opens the Customize dialog box, which allows you to customize the palettes. You can import and export palettes or create, import and export palettes groups.
- Add Tool…:
- Opens the Customize dialog box, which allows you to add a new tool.
