3DOSMODE system variable
Entity 3D snap mode
The current 3D Entity Snap modes are saved through the 3DOSMODE system variable as the sum of the bitcodes of the selected snap modes.
Type: |
Long |
Saved in: |
Registry |
Range: |
0 to 33023 |
Default value: |
11 |
Possible values: |
1: Turn off all 3D snaps 2: 3D Entity Vertices and Control Vertices of Splines 4: Midpoint of edge 8: Center of face 16: Spline Knot 32: Perpendicular to planar face 64: Nearest to face 128: Pointcloud nearest Point 32768: Intersection with face |
