3DOSMODE system variable
实体3D捕捉模式
The current 3D Entity Snap modes are saved through the 3DOSMODE system variable as the sum of the bitcodes of the selected snap modes.
Type: |
Long |
Saved in: |
Registry |
Range: |
0 to 33023 |
Default value: |
11 |
Possible values: |
1: Turn off all 3D snaps 2: 3D Entity Vertices and Control Vertices of Splines 4: Midpoint of edge 8: Center of face 16: Spline Knot 32: Perpendicular to planar face 64: Nearest to face 128: Pointcloud nearest Point 32768: Intersection with face |
