_QUADTABFLAGS system variable
Quad tab flags
Temporary setting used while new quad tab layout is being implemented. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type: |
Short |
Saved in: | Preference |
Range: |
0 to 31 |
Default value: |
12 |
Possible options: |
1: Fixed width tabs 2: Center tab labels 4: Tab borders 8: Double tab height 16: Show 3D Solid mass properties |
