ACADLSPASDOC system variable
on_start.lsp for each doc
Specifies whether on_start_default.lsp and on_start.lsp are loaded into every drawing as are on_doc_load.lsp and on_doc_load_default.lsp, or just when the first drawing opens in a session.
| Type: |
Boolean |
| Saved in: | Registry |
| Default value: | Off |
| Possible values: |
Off (0): Do not load on_start.lsp with every drawing On (1): Load on_start.lsp with every drawing |
