AFLAGS system variable
Attribute options
Specifies the default options for attribute creation. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: |
Short |
| Saved in: | Not saved |
| Default value: |
0 |
| Possible options: |
0: No mode selected 1: Invisible 2: Constant 4: Verify 8: Preset 16: Lock position 32: Multiline |
