ALLOWBREAKLINECROSSINGS system variable
Allow breakline crossings
If breakline crossings are allowed, intersections between breakline segments are calculated and added as points to the TIN surface.
Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Registro di sistema |
Valore predefinito: | 1 |
