ALLOWBREAKLINECROSSINGS system variable
Allow breakline crossings
If breakline crossings are allowed, intersections between breakline segments are calculated and added as points to the TIN surface.
BricsCAD only
Type: |
Boolean |
Saved in: |
Registry |
Default value: | 1 |
