ANGLESAMPLINGINTERVAL system variable
Angle sampling interval
Defines angle sampling interval in decimal degrees, which is used for grading rounding at convex vertices.
BricsCAD only
Type: |
Real |
Saved in: |
Drawing |
Range: |
0 to 90 |
Default value: | 5 |
