ANGLESAMPLINGINTERVAL system variable
Angle sampling interval
Defines angle sampling interval in decimal degrees, which is used for grading rounding at convex vertices.
BricsCAD only
| Type: |
Real |
| Saved in: |
Drawing |
| Range: |
0 to 90 |
| Default value: | 5 |
