ANNOAUTOSCALE system variable
Annotation scaling
Synchronizes annotative entities with the current annotation scale.
Type:
Short
Saved in:
Registry
Default value:
-4
Possible values:
0: Newly set annotation scale is not added to annotative entities.
1: Newly set annotation scale is added to annotative entities supporting it except entities on locked, turned off, frozen or viewport-frozen layers.
2: Newly set annotation scale is added to annotative entities supporting it except entities on turned off, frozen or viewport-frozen layers.
3: Newly set annotation scale is added to annotative entities supporting it except entities on locked layers.
4: Newly set annotation scale is added to all annotative entities supporting it.
-1: Newly set annotation scale is not added to annotative entities (toggled value 1).
-2: Newly set annotation scale is not added to annotative entities (toggled value 2).
-3: Newly set annotation scale is not added to annotative entities (toggled value 3).
-4: Newly set annotation scale is not added to annotative entities (toggled value 4).
