ANNOTATIVEDWG system variable
Annotative drawing
Creates an annotative block when this drawing is inserted into another drawing.
Note: The ANNOTATIVEDWG system variable becomes read-only if the drawing contains annotative entities
| Type: |
                            Boolean  |
| Saved in: | Drawing  |
| Default value: | Off  |
| Possible values: |
                            Off (0): Not annotative On (1): Annotative  |
