ANNOTATIVEDWG system variable
Annotative drawing
Specifies whether or not the drawing will behave as an annotative block when inserted into another drawing. The ANNOTATIVEDWG system variable becomes Read-only if the drawing contains annotative entities.
Type:
Boolean
Saved in:
Drawing
Default value:
Off
Possible values:
Off (0): Not annotative
On (1): Annotative
