ANTIALIASRENDER system variable
Anti-alias amount for render
Specifies the smoothness of the output from RENDER command. For values higher than 1, an anti-aliased output is calculated. High anti-alias values incur a high calculation cost.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: | Preferenza |
Gamma: | 1 to 5 |
Valore predefinito: | 2 |
Valori possibili: |
1: 1x1 (no anti-aliasing) 2: 2x2 3: 3x3 4: 4x4 5: 5x5 (maximum anti-aliasing) |
