ANTIALIASRENDER system variable
消除渲染的锯齿
Specifies the smoothness of the output from RENDER command. For values higher than 1, an anti-aliased output is calculated. High anti-alias values incur a high calculation cost.
BricsCAD only
Type: |
Short |
Saved in: | Preference |
Range: | 1 to 5 |
Default value: | 2 |
Possible values: |
1: 1x1 (no anti-aliasing) 2: 2x2 3: 3x3 4: 4x4 5: 5x5 (maximum anti-aliasing) |
