ANTIALIASRENDER system variable
Anti-alias amount for render
Specifies the smoothness of the output from RENDER command. For values higher than 1, an anti-aliased output is calculated. High anti-alias values incur a high calculation cost.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
1 to 5
Default value:
2
Possible values:
1: 1x1 (no anti-aliasing)
2: 2x2
3: 3x3
4: 4x4
5: 5x5 (maximum anti-aliasing)
