ANTIALIASSCREEN system variable
Anti-alias amount for screen
Specifies the smoothness of on-screen curve display. For values higher than 1 and visual style 2DWireframe (which uses GDI), calculation of an anti-aliased display comes at a high performance cost (roughly a factor 7). For the other display modes the calculation time increases with less than 50%.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
1 to 5
Default value:
1
Possible values:
1: 1x1 (no anti-aliasing)
2: 2x2
3: 3x3
4: 4x4
5: 5x5 (maximum anti-aliasing)
