AREAPREC system variable
Area precision
Specifies the number of decimal places displayed for areas when the area bit of PROPUNITS is on. If negative, LUPREC is used.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: | Registro di sistema |
Valore predefinito: |
-1 |
Valori possibili: |
-1: Use LUPREC 0 1: 0.0 2: 0.00 3: 0.000 4: 0.0000 5: 0.00000 6: 0.000000 7: 0.0000000 8: 0.00000000 |
