AREAPREC system variable
Area precision
Specifies the number of decimal places displayed for areas when the area bit of PROPUNITS is on. If negative, LUPREC is used.
BricsCAD only
Type:
Short
Saved in:
Registry
Default value:
-1
Possible values:
-1: Use LUPREC
0
1: 0.0
2: 0.00
3: 0.000
4: 0.0000
5: 0.00000
6: 0.000000
7: 0.0000000
8: 0.00000000
