AREAUNITS system variable
Area units
Specifies a list of units used for displaying areas when the area bit of PROPUNITS is on. If empty, all areas are displayed in the current drawing unit, as defined by INSUNITS. If multiple units are selected, the unit that fits best is used.
Solo-BricsCAD
Tipo: | Stringa |
Salvato in: | Registro di sistema |
Valore predefinito: | in ft mi µm mm cm m km |
