ATTMODE system variable
Attribute display mode
Specifies whether attributes are visible or not. If the ATTMODE variable is set to 2, all attributes display, including Hidden attributes.
Tipo: |
Breve |
Salvato in: | Disegno |
Valore predefinito: | 1 |
Valori possibili: |
0: Don't show 1: As defined in block 2: Show all |
