ATTMODE system variable
属性显示方式
Specifies whether attributes are visible or not. If the ATTMODE variable is set to 2, all attributes display, including Hidden attributes.
Type:
Short
Saved in:
Drawing
Default value:
1
Possible values:
0: 所有属性都不可见
1: As defined in block
2: Show all
