ATTREQ system variable
Insertion default settings
Specifies whether default attribute settings are used by the INSERT command during block insertion.
Type: |
Boolean |
Saved in: | Registry |
Default value: | 1 |
Possible values: |
Off (0): Use default values On (1): Prompt user |
