AUDITCTL system variable
Audit control
Toggles the creation of audit report (ADT) files by the AUDIT command. When you turn on the AUDITCTL settings variable, Audit creates an ASCII file describing problems and the action taken. This report, with the file extension .adt, is placed in the same directory as the current drawing.
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Don’t write ADT files
On (1): Write ADT files
