AUTOADOPTSIZES system variable
Auto adopt sizes
When On, the wall width and height, and the slab thickness is copied from the highlighted existing geometry, when using BIMQUICKDRAW.
Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Disegno |
Valore predefinito: |
On |
Valori possibili: |
Off (0): The wall width and height, and the slab thickness is not copied. On (1): The wall width and height, and the slab thickness is copied. |
