AUTOADOPTSIZES system variable
Auto adopt sizes
When On, the wall width and height, and the slab thickness is copied from the highlighted existing geometry, when using BIMQUICKDRAW.
BricsCAD only
Type: |
Boolean |
Saved in: |
Drawing |
Default value: |
On |
Possible values: |
Off (0): The wall width and height, and the slab thickness is not copied. On (1): The wall width and height, and the slab thickness is copied. |
