AUTOMATICTEES system variable
Automatic tees
Controls automatic creation of the tee flow fitting in case of T type connection in the BIMFLOWCONNECT command.
Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Registro di sistema |
Valore predefinito: | 0 |
Valori possibili: |
Off (0): Disable On (1): Enable |
